I would appreciate some help from those of you who know electrical stuff.
I'm replacing the deceased Delta VFD on one of our high school's 3520B lathes. It's a single phase input, 3 phase output situation, as I understand it. The 240v power supply cord has 4 wires, red-black-white-green which I understand are 2 active/live/electricity carrying wires, a neutral wire, and a ground wire (in that order, as far as I know). The Delta VFD had R-S-T connections and I believe the white wire was connected to one of them, like a 3 phase wiring. With the single phase 240 input, my understanding is that only the 2 active/live/electricity carrying wires are needed, and they are supposed to be attached to the L and N terminals on the new VFD.
I might add that the plug required to match the school's system is much larger than what is on my 3520A lathe, with 4 prongs, 2 of which have lips/extensions on them, and we had to have an electrician replace the plug on one of the other 3520B lathes to match the wall outlet. He'll be coming back to do the same with this power cord.
Am I correct in assuming that the white is a neutral wire that doesn't carry any current? What do I do with it?
Thanks for the assistance.
