vfd for powermatic
VFDs have become somewhat like TVs or toasters--at least in industry, they are commodities. Pick a VFD supplier, tell them the motor you want to run and the application, and they can direct you to several options. Some brands are better than others and cost more, so it will be up to you to pick your price point. Running a Powermatic lathe is not a terribly demanding task for a VFD.
As Richard says, a search will provide you with more answers than you realize you have questions.
Pretty much any brand VFD will work. It comes down to knowing the parameters you need and doing the programming. Some are more user friendly than others. I like Allen-Bradley personally.
That link also has an option for a 6hp VFD. I wonder if it would be possible to put that on instead? Perhaps it would be unsafe if the other part of the lathe were not made to handle that much more force?
It would be possible. Using a 6Hp rated VFD with a 2Hp motor will not give you anymore than 2Hp.
I've bougfht this on Amazon. They're cheap, easy to program, and dependable. (so far)
https://www.amazon.com/gp/product/B09KN3MS45/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I noticed that they have a 3HP drive available for the same price so it might be beneficial to use the larger one and if the parameter settings are sufficient the overload current could be set to a lower rating, but with the way oversized motor ( for the majority of the time the overloads on a wood lathe are very short time wise) you would seldom exceed the current rating for a long enough period of time to cause it to trip out. Of the 6 VFDs I have in my shop the only one that has ever tripped out on overload is the one on my unisaw and that is due to reaction wood pinching the blade.
Do you know if this model comes with fan cooling? Looks like it might from one of the photos but can’t find text to verify.
This is the exact VFD my husband just installed on my 3520. He made a small write up about it for a fb group that I have in pdf because so many ppl asked. It does have a cooling fan. I happily used it several hours this weekend.
Please post the write up here, if you don't mind. This topic comes up periodically and sharing experiences helps.
