2 days ago, while sanding a bowl held on the lathe with my vacuum chuck, I completed the outside, turned off the pump, and when I turned it back on again, nothing happened. No sucking. I replaced the air filter, blew out the air lines, and checked the electrical connections. At some point of checking things out, I realized the pump would make a buzzing hum when I turned it on. The pump is in the next room, and when listening from that room, the sound was quite definite. (I made a recording of the sound, if hearing it would help) In any case, the electrons are apparently getting from the breaker panel to somewhere in the pump set up.
The pump is a common dual wobble piston pump which has a large, separate capacitor. It was used when I got it 5-6 years ago and I replaced the gaskets and valves at that time. I saw no Magic Smoke, and there is no goo on or under the capacitor.
Could those of you who are knowledgeable about electromechanical things suggest what might be wrong or how to proceed? While I'm not a whiz on electrical things, I've got experience solving other types of problems and fixing things. Also, there's no good electric motor shop around here.
Thanks for any assistance.
