Valve is closed. I removed the hose, only brass fittings. No leaksStupid first question: are you sure a relief valve isn’t open, or otherwise a crack in a hose?
Getting vacuum, but not much".... went to start it, It wasn't cooperating." I assume the pump is running?
1. Check if you're getting vacuum at the spindle.
2. Do you have a ball valve for on/off operation?
3. Gauge may be bad (or plugged with dirt - highly unlikely). BTW- that is not a vacuum gauge like I've ever seen.
4. That round dial (with the orange line) below the gauge looks like it might be a needle valve. I have a similar one but in a different place in my system. Usually when in the full horizontal position the valve is closed (for full vacuum) and when in the full vertical position allows for leakage.
3 or 9 o'clock (vacuum) and 12 or 6 o'clock (open). I think this might be your problem!
I rearranged and shortened the brass tubing. May have changed the line up. Will check again. Thank you all.Could it possibly be that a loose nut on the gauge isn’t cooperating?
That is a pressure gauge, not a vacuum gauge which explains why the needle is indicating less than zero. Also, notice that the units are pounds per square inch (PSI) and, not inches of mercury (inHg). While it’s hard to estimate the uncalibrated scale below zero since zero isn’t very well defined on the gauge, we could make a very rough guess. Twenty-seven inches of mercury is approximately thirteen pounds per square inch so I could reasonably guess that the gauge is indicating about 27 inches of mercury.
Yeah I think what we are all wondering is, how do you measure vacuum with a pressure gauge? Which might be followed up by, how do you know it is low vacuum based on that pressure gauge reading? Dunno. I'm lost here. But then again if you can answer the questions well enough, maybe I learn something.Yes, it it's a pressure gauge, But my issue is low vacuum.
I was previously getting 27hg, now it's not clear as the gauge shows a minus 0 measurement or more.
Yes, 27hg equals 13.3psi. But not knowing how accurate the gauge gets when the diaphragm is being pulled backwards, who knows what it is.Not that the gauge was meant to measure below zero, it looks like it’s reading about 12-13 psi below atmospheric pressure (aka vacuum). So it’s working similar to what you described before as being good. I don’t see support for you comment about the pump not working well.
I like this idea, will try it.Also helps a bit to make a gasket for the base end that screws to the headstock spindle.
I use a rubber gasket between the chuck and spindle as stated above in addition to sealing the wood with shellac and I epoxied the pvc pipe into the wood base.These are the made chucks that exhibit a lower hg. The open end has new foam, and I resealed the backside epoxy around the nut.
I'm not seeing a variation within these 3, so I'm thinking the problem is with the loose threads. Has anyone added Teflon tape to the headstock, and did it help?
A friend of mine, Join Giem, has written a few articles about vacuum chucking for American Woodturner (his Oct 2014 and Feb 2011 articles are about tuning up and Improving your vacuum system). John does use teflon tape on his spindles, as at least one of his chucks does leak there.Has anyone added Teflon tape to the headstock, and did it help?
Many good suggestions so far.These are the made chucks that exhibit a lower hg. The open end has new foam, and I resealed the backside epoxy around the nut.
