Vacuum Pump - oil capture???
Matt you require a De-Mister which is the expensive option or you can make a simple version by getting a tin can filled with Wire Wool or similar, connect the hose from the Pump outlet through the lid of the Can, with the Pipe protruding through the Lid and stopping just [1/2" or so above the bottom of the Can.
Can only needs to be approximately 1/2 gallon size.
Punch some Holes in the lid to allow the Air to escape and you have a basic De-Mister.
The principle is that you slow down the velocity of the exhaust air and entrain the Oil Mist in the Steelwool.
Richard
http://www.laymar-crafts.co.uk
I tried the filter approach with steel wool packed bottle, packed inside a pail of paced shavings. It did reduce the noise but soon after running the wisp of blue began to appear from the shavings and the haze developed in the shop. My final and satisfactory solution in my case was to drill a 3/4" hole through the wall of the shop and feed a clear plastic 3/4" hose from the output of the pump to outside air, problem solved and the air stays clear inside the shop.
