OK - Yesterday I was turning the bottom of a nice bowl. I should have quit while I was ahead and when I had a 1/2" spiggot left holding it. Thought I would be cool and make it about 1/4". Less to carve away. What a mistake. The spiggot broke and the bowl banged around a bit and then off the lathe. Ruined that bowl. What a waste. I am ready to hook up the vacuum pump that I have had for a year or so. But I want to put it up near the ceiling about 10' away from the lathe. The idea I have is to make a shelf up near the ceiling and put the vacuum pump up there and then run copper pipe down to a place near the lathe where I can easily reach the lathe from the wall. Is it going to be a problem having the vacuum pump that far away? I am going to be using a Gast 1/4 hp 110v pump. My thought is that I may loose a little bit of vacuum power but not enough to cause me any problems. Am I right? Thanks ahead of time.
Hugh
Hugh
