Turning tools from Cut Nails
Red Bank NJ
Some time ago I came across an article explaining how to make small turning tools from Cut nails. Of course now that I want it I can't find it. Has anyone come across anything like that?
Bruce,
I have been re-reading through some of my AAW magazines and have just read an article on this. If it isn't in one of the older versions then it's in one of the articles on a web link. If you don't find it in a day or two get back to me and I will retrace my path.
Ruth in So. Cal.
I'll have to look for that article. There was an article about making hook tools. I wrote an article on making tools using a homemade forge or simple torches for heat treating, the same techniques would apply. I'll have to go back and look to see which issue it's in. It was 2 or 3 years ago. I usually make a hook tool out of a cut nail in my tool making demo's.
Concrete nails
Concrete nails, hex wrenches, drill rod, HSS metal machining bits, and other materials can be made into different kinds of turning tools.
My preference is for HSS bits. 1/4" x 2-1/2" bits are about a dollar, and the quality is incredible. They come in round and square shapes. They don't have to be tempered, just grind and use. They don't easily lose the temper when grinding. Don't dip in water as you grind either, if they are hot enough you will have microscopic cracks in the edge.
You will need to make a handle for the HSS bits, just like any of the other materials.
