I took on a job for a customer of mine. Still not sure if this is the best idea but I am going for it.
Customer has a 16"x6" cement sink that has a small crack (sits on top of the counter) and wants a walnut bowl/sink. It is in the guest bedroom with minimal use.
Because of the drying time of working with a solid blank I was going to get some 8/4 kiln dried lumber and glue up a block.
Any one have advice on finishing this?
My plan was turn it to 90% then use a penetrating epoxy or stabilize it like I do knife handles in a vacuum chamber. Then finish turn it and pile on the coats of my Sam Maloof style Danish oil. I cut it with a Spar Urethane (1/3) with a UV inhibitor.
I kind of wanted to stay away from a solid epoxy finish if I could.
Thoughts or advice on this?
Thanks,
Kris
Thanks,
Kris
