- Joined
- Mar 6, 2006
- Messages
- 2
- Likes
- 0
Does anybody know of a good place to get High speed steel? Trying to make some tools and can not seem to find the material.
What size would be a good place to start. Small, say up to 1/2x1/2"x3" in M2 or even cobalt is easy to come by at almost any big industrial tool house (McMaster-Carr, Enco, etc).roblchatster said:Does anybody know of a good place to get High speed steel?
aplpickr said:Look at High Speed Ground Round Tool Bits. Try part # 2227-0020 for starters. $30 will get about 20 pre-hardened M2 HSS pieces that can be worked with grinders, but not saws and files. Others like ENCO, MSC have these, but M2 can not be hardened at home, like oil hardening can be. Link:
http://www.wttool.com/Merchant2/merchant.mvc
Bill in WNC mountains
Most steel you buy is unhardened (O,A,D,S7). The M2 (and the tool bits) are hardened and will require more grinding to get to shape, will hold the edge better. If you have access to a kiln, hardening and tempering isn't really all that difficult.Understand that most turning tools are rated hardness by the Rockwell C scale.Myrel Willeford said:Would D2 air hardened tool steel work as well.
