Short answer - no. Some are not urns, some have slide fits on top, and some have removable bottoms.
The cremains are normally delivered in a plastic bag, so I wouldn't make the neck of the vessel too narrow or you'll be decanting. Leaves out most of the brass type threads you can purchase from turning places. If you want threads, get some 4" PVC pipe fittings, male and female, and glue them in. That way you can open and close often, though why, I do not know.
Just a taper twist fit is fine for a spreading ceremony. You can modify it with a parting tool and hydraulic O ring to get a nice tight fit that way too.
