OK I went to the shop and played for about an hour or more with my various thread chasers and some different woods. I learned several things. First I haven't done any thread chasing for a couple of years now. I much prefer my Baxter threader. The topic of lubricant to make thread chasing easier came up and I thought it was worth a play since I had the necessary ingredients. First of all, good wood is king. If you have good wood it chases easily and cleanly. Other woods can be really challenging. Second of all. The commercially made chasers I have are thicker, have an 80 degree angle on the front. I have several homemade chasers that have a more acute angle on the front and they work well. I had one homemade chaser that was 90 degrees. It's harder to use. I'm going to regrind and file that one. I put a negative rake on the top of my chasers based on the recommendation from a very famous turner who I can't remember at the moment. That works. I had several of the older chasers that were flat on top. They worked but when I put a negative rake on the top it was easier to find the thread.
I tried thin CA, Johnsons paste wax, Dawn dishwashing liquid, and Kerosene. Best I can tell. Any of the lubricant seems to help. I think your skill with the chaser helps more (and wood choice far more). The CA was kind of hit or miss. If I applied some Ca made a pass or two and then applied more it did seem to help on the softer woods. Not much change on the harder woods probably because it doesn't penetrate. With my limited playing I think the paste wax and kerosene worked the best with the least hassle. Could not tell the Dawn did all that much. I did try all of them with the 36TPI chaser and all worked better than none at all but the poor woods just can't handle that fine of a chaser.
Below is my collection of Hand chasers. The ones with Blue tape are pairs, the ones without I'll have to build the mate some day when I have time. The ones with tip protectors are my homemade ones. So are the ones with Walnut handles. The one with a spalted handle is just a 16TPI bolt that I sawed in half. It works but difficult to cut the male threads.
