Thompson Bowl Gouge
I am reading alot about Thompson tools and in particular the bowl gouge.
I am in search of one and was wondering does anyone own one of these and what do you think??? Is there a size preference and why?? I was on his site and I see he offers a Jimmy Clewes gouge too. Is this better or is it the same thing??? I see also there is a V and a U shaped one. What would be the difference and woulld one be more useful over the other??? Any thoughts would be appreciated. Thanks.
I think that the difference is mainly a mater of preference. The V is somewhat reminiscent of the Jerry Glaser bowl gouge. All of the bowl gouges that I own are more or less U shaped, but I don't see a major difference other than a particular shape might be better for putting your favorite grind on the gouge. The Glaser grind seems to be a bit too aggressive for my style of turning.
Hi John,
I have several of Doug's tools. Mine are all the V shape. The reasoning is, that is what I learned on. But they are very different from my Glaser tools. The V is not nearly as severe as Jerry's tools. Doug's V flute is a little more open on the bottom. I find that it fits the grind I like to use perfectly.
I have not used the Jimmy Clewes gouge, so I am not sure what the flute is like.
I would give Doug a call. He is one of the good guys and will be happy to answer any questions you have.
Dave
I took a look at my Thompson bowl gouge and I suppose that it is a V, but as Dave said, it is not nearly as radical as the V on my Glaser. I have several different brands of bowl gouges and the shape of the channel is different on every one. I do not particularly try to copy a grind named after a famous turner when I grind them. I just grind them the way that I want (after all, when I become famous ... ;)).
I have a 3/8" Jimmy Clewes bowl gouge and a 3/8" detail gouge from Doug. They are the best tools I own.
The Jimmy Clewes is what I used at a three day class with Clewes. I tried several bowl gouges, including the one I brought to the class and kept coming back to the Clewes. The deeper V flute allows me to get into and through the radius of the bowl cuts easily and smoothly.
The detail gouge is versatile and very accurate. It goes where I want it to and does what I have in mind as it gets there.
After a bit of time passes and my wife recovers from the sticker shock of this new pastime, I will order 1/2" versions of the same tools from Doug. I like the idea of having found the best source for the sort of tools I want to use.
I've got several of Doug's gouges, and they are my go-to tools for nearly everything. I've not used better gouges. More often than not, I tend to use the V shaped bowl gouges for the outside curves and the U shaped gouges on the inside. I keep longer, straighter wings on my V shaped gouges, which I prefer for shearing cuts. I'm sure other turners have totally different preferences. I seem to recall Doug posting somewhere a while back that the V shape gouges were more popular with his customers, but I'd have a hard time getting by without my U shaped gouges, too.
If your budget allows, I'd suggest starting with one of each shape. You will use both, even if you end up preferring one over the other. ;) BTW, his 3/8" shallow detail gouge is also sweet. And my Thompson skew is probably a great tool too, if only I could operate it. :rolleyes:
The V shape in Doug's gouges does not clog up like some others and as noted the Clewes V is deeper than Doug's normal V.
Bill
The single most versatile tool might be Doug's 1/2" V with a moderately swept back grind. I use the 5/8" V mostly for roughing and the 3/8" V for smaller work. The 5/8" U is almost a C shape. It seemed just too big for me to control easily, but I do plan to get a 1/2" U. The V's are a bit more severe (deeper) than my old Sorby, but less severe than my Ben's Best. I dislike the "deep" V of the BB's. For me they are too pointy (technical term) and hard to control. I reground the 3/8" BB V into a sort of detail gouge with long wings. Very pointy, a little tricky to use but handy where needed in tight spots.
Good place to start might be with a 1/2" V and a 1/2" U.
I have 2 1/2" V gouges, one U shaped gouge, 1/2" spindle gouge, 1/2" detail and 3/8" detail, and a 1 1/2" skew. I absolutely love his tools and hardly turn with my others anymore. One of my 1/2" I've ground to be the same as Johannes Michelson. I'm still to new on this tool to tell you much but it is interesting and seems to work well.
on the way...
Bill!!!
You are too modest! "When" you become famous? I think you are underselling yourself [a good quality, because it is much better for others to throw praise your way, than one to praise themselves] :D
I have the 1/2" and 5/8" V gouges. I use the 5/8" to rough the bowl and the 1/2" to finish with. They don't seem to clog up like the other brand U shapes I have.
Hi John,
I also use the Thompson tools and as my existing tools need replacement, I am purchasing the Thompson’s as replacements. They seem to last longer than others that I have used. I actually like the ‘U’ shaped better, they seem to clog less with chips.
Good luck with your choice, either way you should be happy.
