Thin Accent Material
Newburgh, IN
I'm looking for ideas associated with different materials to use as a thin accent in turnings, e.g. thin piece of maple with walnut, etc.. Obviously a thin piece of wood works very well, however I suspect a number of turners have found other solutions, i.e. thin plastic of some kind, etc. Any thoughts or ideas would be appreciated.
How thin? I know there are a number of veneers you can buy, and probably lots of different species. You can buy 1 1/16 inch thick baltic birch plywood at toy stores that carry stuff for people who make RC airplanes.
Newburgh, IN
Thanks - am thinking 1/16, 1/8, in that range. Will keep this in mind. Thanks
Colorado Springs, CO
I normally use colored wood veneers to separate contrasting embellishments on yo-yos, for example, this Swiss Pear body and ColorPly lamination:
I also use a lot of knife handle scale materials for laminations:
But for good looking laminations to work, you have to get the mating surfaces perfectly flat.
Haubstadt, Indiana
Guitar pick material is one I have used in the past. With plastic like materials I use epoxy when making the laminations. You can find in colors with the most poplar being white sandwiched between black.
Hmm, that makes me think of the plastic pick guard materials used on the electric guitars. Some of the ones on acoustic guitars has that turtle shell type pattern, and a host of others. Not sure how you would glue it up....
Newburgh, IN
Bill indicates he uses epoxy to glue it up.
Haubstadt, Indiana
Well I guess I don’t understand your concern. I have glued plastic to wood many times. With the guitar material you need to rough the sides that will be glued and use epoxy glue. Below is a picture of the material I have used. Bottle stopper with the laminated material.
BB219560-D361-480A-9676-95FB7F6AB694_1_201_a.jpegD72ADD32-A49D-4962-878E-D89F692DC73B_1_201_a.jpeg
