The screw you use with faceplates
Marietta, Georgia
Most turners know better than to use sheetrock screws when mounting wood to a faceplate. Ive also had my share of deck screws snap off on me.Then I found a box of screws at Home Depot that looked like a better choice, concrete screws. The brand I found is Tapcon by ITW Brands. The minimal shear strength listed on the box was over 700 lbs and the pullout from concrete about 350 lbs. So far these this have been pretty well bomb proof.
Yep, a good choice and safe, for the rare times that I do faceplate work anymore. I used to turn a lot of big architectural stuff like column bases and capitals.
The screw should be made from a metal that is not brittle and won't shear off or break, sheetrock screws will twist and break easily, an easy test is to mount the fastener in a vice and bend it back and forth with some pliers to see if it breaks. A good quality metal fastener will withstand some bending and twisting without failing right away. Sheetrock screws are designed as a cheap one time fastener, it is no fun trying to dig one of these screws out of a wood billet when the head breaks off and the screw is left in the wood.
Ellesworth recommends sheet metal screw, #12 or #14, with 3/4" to 1" penetration.
If you are loading the billet onto the lathe with one hand or using a forklift to lift the billet onto the lathe there might be a slight difference in the fasteners used to secure the billet to the faceplate. :-) Once you move into the bigger pieces calculating the fasteners strength and loading characteristics would be wise, in the industrial world a 400% safety factor is a good rule of thumb.
#12 SPAX. 1-1/4, 1-1/2 long. Very thin threads with the first couple of threads having a saw tooth edge. They displace very little wood. Power drivers will strip any screw-I always run them up and finish with a screwdriver by hand. I used to take just a screwdriver to demos, people couldn't believe I was going to install six screws by hand, but it only taks a minute with the SPAX screws. Of course I only turn green wood, might want to predrill some of the harder dry woods.
I used a lot of drywall screws 30 years ago and don't remember breaking any, but never since the SPAX screws came along.
John
Putting a screw of any kind into wood without drilling a pilot hole just spreds the fibers? Its so quick to drill 4 or 6 pilot holes, why would you not drill them?
I allow a 1/4” of extra length for the faceplate tenon to allow for the opening the screw will make ahead of itself
With wet wood there is no need for a pilot hole with #12 screws.
I find it easier to center the faceplate by driving one screw 1/3 the way in checking then putting another screw-in check and then all the screws.
If I miss with the first screw - I just remove it and try it in another hole until I get the faceplate on center.
Too hard to move a pilot hole if I miss.
I have a faceplate for a DIY disk sander. I put the wood on and turned it round. Use PS sanding disks. No need to try to center the wood before installing. Screws are FH Slotted #12-3/4.
I use #14, SS, oval head sheet-metal screws with a Oneway faceplate. The 6" faceplate has 18-holes so I use 18-screws. The tenon is cut flat and the holes are centered with a hinge bit then drilled with 11/64 bit with depth-collar. Never had a problem with face-grain up to >300-lbs and end-grain mesquite >300-lbs. Length is 1.25" - I sometimes use 1" on the outside holes for lower profile designs - that allows me to "dive under" the faceplate for a 4" base without worrying about the outside holes showing.
While the above may be a bit excessive, to my thinking it provides a greater margin at zero expense. I've used the same screws for over five years and precision drilling cost nothing. One the other hand, getting hit in the pearly whites can be expensive.
That's basically what I use for my Oneway 6" and 10" faceplates. The only difference is that I use flat heat head rather than oval head (I'm cheap). I have various length screws from 1¼" to 2" depending on what I might be turning. Since these are #14 screws I predrill the holes and wax the screws.
+1 on the stainless screws - been using the same set of #14 button headed, square drive sheetmetal screws for about a decade and a half. Leftovers from a misadventure in boatbuilding. Got several lengths. They never wear out - just make sure I don’t lose any.
Tried to use some of the silicone bronze screws left over from fastening planks but the phillips head drives would give out after a couple of uses.
Geesh, and here I spend so much time looking for actual wood screws. Gettin rare as hen's teeth some places.
I think that the problem with the old fashions wood screws with a slotted head is that they really aren't very good for holding wood compared to newer screw designs. :D
Self-centering hinge bit, never miss the lineup hole.
:). This bit can’t drill in the wrong spot? :)
I get that it will drill in the center of a faceplate hole. This will work if the faceplate is in the right spot and doesn’t move before the drill gets started.
I just don’t need two two tools to put on a faceplate.
Well said. So many screws, so many choices. I'm a retired Mech. Engineer and a lifelong DIY'er. Deck screws are pretty much horrible for anything but "deck boards".
It really is pretty simple though to find the right screws for face plates. Only use screws that are labeled as "structural" or "construction" screws. They are made from ductile material with high tensile strength.
My favorite is Simpson, they make some really good quality structural screws. GRK makes some decent structural and construction screws. Simpson and GRK are available at Home Depot.
Again, look at the label on the package. If it doesn't state "Structural" or "Construction" screws.. don't use them.
OMG! Did somebody leave the door unlocked and let another engineer in here? Heaven help us.
(In truth, I really, really appreciate the expertise and compulsiveness all you engineers and material scientists bring to the discussion. Sometimes, the urge to tweak just gets too strong though ;))
