I do most of my work with my gouges and skews, but with some more exotic woods I've found that the touch of the scraper is best. For years I used the Veritas burnishing jig which makes a "forward" burr, but then put is aside and went "purist" and hand burnished a slight "back burr". I've fine scraped with my skews, and made negative bevel scrapers, and they work fine for final smoothing.
I'm working on a 6" slightly enclosed bowl of Indian Rosewood, and the wood is a bit "chippy" so I decided to smooth it out with a scraper rather than my normal way of using David Ellsworth's "finishing cut" that I can do quite well on other woods
That is background, I really do know what I'm doing. My question is this. Should I stay "purist" and hand burnish the burr on my scrapers or remount my Veritas burnishing jig and get a "forward burr" consistently. It seems to me that the angle of the burr to the horizontal shouldn't matter if the presentation to the workpiece is right, but my instinct also tells me the the "forward burr" might be a problem when shear scraping.
I can adjust the angle of my burr when hand burnishing, but I'm also not going to be as consistent as I would if I went back to my Veritas jig (the 10 dg. forward and the 5 dg. forward options). I am aware of the different tool rest levels and the "angle of the dangle". I ask advice as to which is the more versatile for various woods.
Best, Jon
Best, Jon
