The Best Bandsaw
Southern Utah
Hello,
I have been looking at a few bandsaws. However, every company I have asked says that they are the best. I would like to know what people have experienced
with Jet, Laguna, RICON, Powermatic, Meber, and whatever other bandsaws there are out there.
Thanks
Wyatt
Best Bandsaw
Hi Wyatt. I have a Minimax MM16 which is an incredible machine. It will resaw 12" and cuts anything I ask it to with amazing accuracy.
Ken Cawley
The best bandsaw is a saw who has one wheel that can be directed vorwards and afterwards: so the saw itself runs always correct and can be corrected.
Very few bandsaws can do that but if you find such one, an older one, second hand - it is worth buying it.
Squirrel
Don't know about Grizzly. I've a MiniMax MM20 that is just about perfect (it'd need to have an automatic log loader to be perfect!). 20" resaw, 20" depth, and a huge table. I looked at both MiniMax and Laguna, but it eventually came down to shipping costs (I'm on the east coast) and Laguna didn't quite have the capacity for overall size as the MM20.
go514x2
I have a Grizzly GO514x2 works well also us it for resawing flat boards works great on cherry and black walnut.
One of my best friends just went through that. He chose the Mini max. He and I looked at all sorts of bandsaws from Jet, Rikon, Steel city, Laguna, Powermatic, Mini max, and Delta. The new powermatic may be one of the best but was a little beyond his price range. I think it ran about $4000 if I remember correctly.
I have a PM 143 which should not be confused with the current offering of 14" bandsaw from PM. Although I don't have the height of the curent BS, the weight and the transmission case which allows metal cutting is a real boon. The times I wish for a larger BS are only when I'm cutting turning blanks. I can do this reasonalby well with my chain saw. Well enough, that is, to not give serious consideration to a larger saw.
For general woodworking, if you can find a used PM 143, grab it.
If I were to buy a larger saw, it would be a PM.
A friend of mine has this one:
http://www.lagunatools.com/bandsaw.lt14se.aspx
I have this one:
http://www.cpowoodworking.com/band_saws/28-276.html
Just by comparing the features you can see why I think his band saw is better than mine. But my wallet is thicker than his. I guess it depends on how much you're willing to spend.
Mine works well, hasn't given me any problems, cuts straight when I need to and cuts arcs when I need to and I take my wife out for dinner a couple of times a month. That's a win/win in my house.
It depends on how big you want to cut. For just rounding out blanks, then any of the 1 hp by 14 throat by 12 inch high (which includes a riser block) will do. They are designed to cut 6 inches high, but can work with the riser block, but are not built for production cutting at that height. The bigger, built for 12 inch cutting saws ), Jet, I think Rikon and a few others are better than the riser blocks, and have more horse power. If you want to cut bowl blanks, then bigger is better. The 24 inch Laguna is one such saw, but with almost 10 hp, and 3 phase, and almost $10,000, it is a bit much for me. I do have a 16HD Laguna, and I use it for prepping bowl blanks. It cuts an honest 16 high, and bowls bigger than that are a specialty market. I thought I could do a good job on bowl blanks with my chainsaw, but this saw paid for itself a couple of times within the first year I had it. I start with half log sections. The saw cuts faster, and more accuratly than the chainsaw. I am guessing it cut my prep time almost in half, and my turning time by 1/4. I also end up with a much rounder and more balanced bowl blank, so my turning time savings are big as well. I do prefer the ceramic blade guides to the roller guides. Much cleaner. The only thing I don't like about the saw is that there is no real way to fine tune the riser post (the one that raises and lowers the blade guides). Mine was bent on arrival. I have a smaller industrial PM, and the post is square with gibs (jibs?) that allow you to fine tune it. I don't know about the Mini Max in this matter. A sled of some sort would be really helpful. From all I have read, the saws are comparable. Aggazini is another bandsaw I have heard of that those who own one start drooling when they talk about it.
Thanks Reed,
I have a Jet 18" but have been considering selling it and getting a nice big Laguna like you have. Could you give me more information on the price and how your Laguna saw functions?
Thanks
Wyatt
I think I have had it for 3 plus years. Price was in the $2500 range. I had to wait for a container load to come in before they shipped it. They used to ship the saw on a pallet, not in a container or wood frame. When it got here, 2 of the bolts used to secure it to the pallet were gone, one was almost out, and the other was loose. There was some damage to the upper blade guide. I bent it back onto shape. It works great. I use Lennox bimetal blades, 1 1/4 with about 3/4 inch spacing. I have a Lennox dealer here in town, and he will make whatever blade I need. You only need a carbide blade if you are cutting veneers. I think the dust port has been changed. There is a cross hair in the middle of the port, and I removed that first. I later removed the plastic insert that is 4 inch diameter, and then put in a 5 inch port. I have an Oneida 3 hp system, and 5 inch lines to all machines. I cut both ends of the blank off square to the flat chainsawn side, then stand it on end to cut the bottom off, and trim up the top if I didn't do a good enough of a job with the chainsaw. Standing the blank on end results in long fibers, and the inside of the saw reminds me of the Star Trek adventure 'The Trouble With Tribbles'. It was worse before I cut out the cross hairs (which are there to prevent any one from sticking their hand into a moving saw). You will need a 30 amp fuse for it to run on. I did have a little trouble with belt slippage, but it is easy to adjust. The wheels were in line with each other when it got here, but the table was not square to the blade. Some times I have thought about putting some sort of panel, like formica behind the upper wheel to keep all the saw dust and shavings away from the post that holds the upper blade guide. There is a lot of stuff up there for the shavings to get tangled up in. Have also thought about a tube of some sort around the post as well because dust and shavings can get in the gear teath on the post. After reading this, please remember the engineers motto: if it aint broke, take it apart and fix it anyway. I don't think I have gotten a maching yet that I wouldn't modify in some way. The Mini Max is comparable.
Oh yes, I don't use it for cutting circles. The 1 1/4 inch blade doesn't cut too tight of a radius, but I do round off blanks that are over 6 inches. My small PM has a cast iron body, and a riser block won't fit on it. Blade changing is simple.
There is no such thing as a "best" bandsaw because everybody has different ideas about what they like in a bandsaw. Like several others, I also have the MiniMax MM16 and it is a fantastic machine -- extremely well built, heavy duty, and powerful. It is what I wanted, so it was the "best" for me, but not necessarily the best for someone else. I would definitely steer clear of benchtop bandsaws or three wheelers. Also, I would avoid no-name or store brand saws. Multiple speeds is just a gimmick -- you only need one in the range of 2700 to 3400 feet per minute. Finally, while a 1/2 HP motor will usually suffice, it is much better to have one that is at least 3/4 HP with an AC induction motor ... definitely no universal motors, which is what you find on routers and drills.
And how much you want to spend
I have a 24" Laguna, with greater than 24" resaw, but with a 5HP motor, single phase 220V. Have cut 24" thick logs. Takes greater than an 8' ceiling though.
LeNeave
I have recommended the 21" LeNeave Northstate bandsaw to people and everyone who bought one is satisfied. An experienced turner who has a Laguna has used this one and prefers it to the Laguna. The LeNeave is also a LOT CHEAPER than a Laguna. LeNeave is in Charlotte, North Carolina, and is an excellent group to deal with. If you call, ask for the "Ed Moore Special" and NO, I don't get a penny, but LeNeave gets a kick out of it. :D
This saw looks like a Grizzly, but it is better made and finished and I think it uses thicker steel. It has a three horsepower motor and it doesn't stall.
Check out:
http://www.leneavesupply.com/Machinery/NorthState/P04049.aspx
Check out the General 20" bandsaw...this is a tremendous machine. Cast iron, even the entire base. We use one at Brookfield Craft Center in CT., this saw will last several lifetimes, even under heavy industrial use. Next to a restored Oliver, my dream saw.
Since you don't mention price, I'll throw out Tannewitz as a contender. I worked for a company which had their bandsaws for cutting up aluminum castings. They were built like tanks and they do make woodworking saws. Generally they are considered industrial rather than consumer machines.
http://www.tannewitz.com/m_catalog02_07.asp
At 2900 lbs. This is probably a good contestant for "the best"!
http://www.tannewitz.com/tannwood/prod02.asp
MimiMax
Go with the MiniMax. Good value. Superior quality. Excellent service. Don't think you can beat them with any other saw. They have a HUGE European company behind them. See http://www.scmgroup.com/html/index.html;jsessionid=MEAMONHECMBI?locale=en. You will see MiniMax listed under SCM Group companies. Support is never going to be a problem with a large company like SCM Group behind the product. - John
John, I wouldn't assume the best customer service with SCM just because of their size....When our computerized SCM edge-bander failed (Windows failure)at my workplace, it took three weeks to have a new computer shipped to us...after they were unable to repair the original unit. When the new unit arrived, we discovered it had not been programmed for our particular machine. Another two weeks for a service rep. to arrive from California. Two days to figure out the problems with the new computer. This is a $70,000+ piece of equipment still under warranty. The machine was supplied with a service manual printed in Italian only....not very user friendly!
Just thought I'd add my two cents onto this thread!.......
A lot of my equipment is "as old as the hills", and my Grizzly 16" band saw is no exception! I bought it new, but it's now about 20yrs old. For my needs, it works well.........it's 15 7/8" throat and 10 1/2" cutting height is perfect for my needs.
It originally took a little too much effort to change over blades, but I did some modifications that helped speed that up a bit.
I also found it necessary to add some angle iron to the base in order to increase it's stability a bit.
There are some minor flaws in the castings that were a little irritating to me.....but, over the years, that has had less significance.
This is my third band saw. The first was a 10" (or was that a 12"?) Craftsman. I then graduated up to a 14" Jet for a few years. Then I got the 16" Grizzly in the late 1980's.
I think the band saws being produced today might be better......at least they are now offering higher capacity band saws that are within reach of the average person's budget!......but I have no plans to ever part with my Grizzly!
Is my Grizzly the best? No, far from it, but it does everything I require of it. The "best" label will be properly attached to some of the more recently manufactured band saws......I think!
If one like my Grizzly 16" band saw were to be offered on the used tool market, at two or three hundred dollars.....it would be a steal! I can't remember exactly what I paid for mine, but it seems to me it was in the $600 +/- range back in the late 1980's.
otis of cologne
conflicting band saw color
I also was all set to buy one and then I found out that beigetone was the only available color -- a deal breaker as that color just would not "go" with any of the other tools in my shop. :p
Bill
Bill-Not to even mention your conflicting smock colors!!!!!;)Gretch
