- Joined
- Aug 7, 2008
- Messages
- 18
- Likes
- 0
You get what you pay for....I bought a $79 lathe at Harbor Freight ... model #45276 as soon as I get the spindle adapter a 3/4-Inch x 10tpi to 1-Inch x 8tpi and my new Grizzly H6265 chuck looks like I will be ready for some great turning ..many thanks to all the form members for there great help and advice!! But.... I think I am having a problem with the tailstock not lining up I thought it was just me not finding center on the wood. But after using a laser lever to test the alignment from the headstock's to the tailstock. I found that the points did not line up. I placed the laser on top of the head stock's spur point, then I moved the tail stock up and down the length of the lathe several times the farther I got away from the headstock the more out of alignment it got .. it was off about ¾ of an inch. With the laser light coming of the headstock I could not get the tailstock to line up.
But if I placed the laser on the tailstock and pointed it toward the headstock I could then line up the to points by moving (turning the tailstock slightly counter clock wise..hum whats going on..maybe am not doing something right. Any ideas are suggestions.
I suppose this is just my cheap lathe characteristic! 😕
