I bought a pm 3520 a year ago and at times (not all the time) I notice the tail stock quill moving as if it were out of round (turning noticeably in an oval) instead of perfectly round and balanced. When I notice this the most is after turning the base and foot then reverse chucking.(ex. Bowl turned last night with foot side first, reversed with interior facing tail stock and tail stock being used for additional support.) This doesn’t appear to happen all the time (although I’m wondering if it may not be as noticeable at times) and my first impression is that it’s off center. It literally wobbles like a tire out of round. I’ve checked the alignment, made sure I’m cinched down with the levers and it’s fine. What I can’t figure is how can it be off center with a cone center attached to the live center that has been engaged in the wood after is is chucked. This has also happened with green pieces rounded on the bandsaw for natural edge bowls. Usually it surfaces as I’m turning the base. It will be attached with a screw center in the top for natural edge and tailstock pulled up. When I turn the juice it wobbles (maybe). I would think it would have to be centered, could it be the blank out of balance forcing the quill to move in this motion and since it's locked down this is the only thing it can do except break. I’m convinced I’m doing something wrong.
Thanks
Thanks
