I had an issue with a Supernova2 chuck in that as I tightened or loosened it, the slides would bind up and be very difficult to turn. I took it apart and soon realized the number one slide was hanging up. I cleaned it thoroughly and decided while the chuck was in pieces, to service the other slides as well. Now, none of them slide as they should, rather all get hung up about half way in. I lubricated them with WD-40 and then a dry lubricant - both to no avail.
In working with Teknatool support, they suggested moving the slides to different positions to see if that help. It did not. They then recommended lightly filing the slide guides to free them. Have tried this as well with no luck.
Attached is a photo displaying how far in they go before getting hung up, and also an end view of the number one slide. Of note is that I had the same issue with a different SN2 a year ago and ended up sending it to Teknatool and they made the repair.
Has anyone experienced this same issue and if so, been able to resolve it?
Thanks
Roger
