Stupid Turner Tricks -- Stopping the lathe with your hand
Don't try this one at home. Leave it to the professional safety officers to prove that this is dangerous and not a smart thing to do.
The rimmed bowl was not very large and had almost coasted to a stop. But, the mesquite bowl still had plenty of wood along with the hefty chuck, lathe spindle, pulleys, and motor armature all contributing meant that it still had a good amount of momentum. I mentioned that it had almost coasted to a stop -- in this instance, almost meant that it probably would have come to a full stop in another nine or ten seconds ... fifteen at the most. I do not usually make rimmed bowls, but this one was a special request from the lady who tells me that my turnings look good enough to display in the house (most of the time) so it was put on the front burner.
Anybody who has ever turned mesquite knows that borers like it as much as woodturners do. The abundance of tunnels frequently presents turners with an opportunity to collaborate with the bugs -- or else waste away lots of wood. This particular chunk of wood looked like it had some tunnels in the heartwood that might work as a collaborative piece so I decided to include some of the bug work in the piece.
After a bit, it became apparent that the edge of the rim was a little too ragged with tunnels to work well so some of those tunnels needed to go so that the rim would have a nice smooth edge. However, I wanted to be careful to not reduce the width of the rim more than absolutely necessary so I made a mental note of where "absolutely necessary" existed. This would be a good time to mention that pencil marks are often better than memory for making accurate notes such as this.
One other thing worth mentioning is that your hand is not a very good substitute for brake pads. It turned out that while using my hand brake to stop the spinning bowl that I learned that not all of the bug tunnels had been removed from the rim - see the attached snapshot. That little hook-shaped notch caught the webbing between my thumb and index finger and ripped a ragged gash about 3/8" deep and a bit more than 1/2" long a it passed through my hand and slowing down only slightly. If there is any good news, it is that the bowl was unharmed in this unfortunate encounter.
This was my first and hopefully only lathe injury to draw blood from contacting spinning wood. I have had a couple of bad cuts from very sharp hand tools (a woodcarver's chisel not being used properly and contact with an inappropriately stored bowl gouge -- sitting pointy end up in a five-gallon bucket). I learned something worth remembering about pain -- being cut with a super sharp tool is nearly painless for the first hour or two. The pain starts later after being sewn back together by the ER doctor. However, a ragged gash made by a relatively rough-edged chunk of wood hurts like Hell right from the get-go!
I wrapped the cleanest filthy shop towel that I could find around my hand and headed to wash up the wound. Somehow after washing up the wound, I managed to simultaneously keep the pressure on while applying several butterfly closures and a pressure pad. Amazingly everything healed very nicely in about ten days with no missing pieces in the jigsaw puzzle that was my right hand.
So, what are the lessons to be learned? Here are a few things that come to mind:
  1. In wood vs. flesh, wood comes out ahead every time. I could not find even a slight bit of damage to the wood.
  2. Wood does not need to be sharp to tear through flesh.
  3. The pain of torn flesh is incredibly intense. It hurt so much that I could not even manage to utter any oaths against the wood.
  4. I don't plan on installing brake pads on my hands so that means that a spinning turning can just coast to a stop on its own and I will find other things to amuse myself while waiting for the lathe to stop turning.
  5. Would leather gloves have helped? I think that they might have made things worse -- here is why: I believe that the glove would have been hooked and caused my hand to slam against the tool rest -- possibly dislocating or breaking one or more fingers. That type of injury with ligament damage is very slow to heal -- taking at least a year and probably never regaining full function.
My woodturning club bestows a good-natured "Safety Officer" distinction to members who have injured themselves as a way to encourage safe turning by sharing personal experiences. It is not the kind of recognition that members intentionally seek, but we willingly share our lessons learned so that hopefully we all don't have to go through the same mishaps while learning the wrong way to do things.
Glad that was only a flesh wound, Bill. I will slow down my little mini-lathe by grasping the handwheel, and I can see how if I were concentrating on the wood I might touch the wrong thing. Maybe a brake pad isn't a bad idea....
I assume you've already received your safety officer award, so there's no point in making a special trip to Fort Worth to cheer your presentation.
That's the important thing.:rolleyes: Seriously, we all sometimes forget and do things that are not kosher. Glad everything is doing OK.
I cut my thumb while making a salad; Clinic charge was $310 for three stitches. Should have gone to medical school.
Man, glad it wasn't worse. I'm thinking you need to build a foot powered brake that can instantly be installed and removed and placed wherever it's needed. With a pneumatic braking system you could stop the bowl in a couple of revolutions, inspect it and be back to turning in less time than it takes for the bowl to slow down.
Bill,
Glad it wasn't worse. Thanks for sharing. It may save some others.
I don't think gloves would have helped.
I wore gloves with cut off fingers for a short time. When I first stated using then,
I got the dumb idea that I could stop a bowl now that my hand was protected.
I stopped the bowl, my hand was fine, the palm of the leather glove had a 3" sliced opening.
Can't imagine how my hand did not get cut.
About 6 months later I was working with CA glue and a drop got in the cut off finger
It did not bond the glove to my hand.
It got hot and burned my finger. Hurt a lot and left a big burn blister.
No more gloves for me.
John,
Saw a demo with a strobe light by Ron Gerton.
He also wrote an article in the journal.
Don't have to stop the lathe the light stops the image for you
Ron used it in the demo to work something like a root ball.
We could see all the little projections and he could leave or cut what he wanted and see it.
Thanks for posting this it will be presented to my club members at our next meeting if that is ok with you .my first and only one was when I caught a spinning block of 6*2 with the skew it hit me in the mouth lots of blood but only a split lip now I wear my face shield in stead of keeping it safe on a hook above my head :eek:
Ian
Bill, I'm glad your hand has recovered.
I especially appreciate hearing that club members share stories of their accidents with each other. I think it helps everyone be more safety conscious.
Betty Scarpino, editor, AW
Bill, be honest now! Were you wearing your faceshield? Your years of experience, as some of us have already learned, has nothing to do with safety. I finally had to make up a "starter" list of "to do(s)" that would be the first step before going into my shop: (1) unlock shop and open door. (2) put brain in gear. (3) Press "Start". :D
Sorry Bill; glad you're okay, but I got you beat. Wasn't going to post this, but since we're on the topic:
About a month ago, I was turning a bowl, and was finishing up the outside with a shear scraper. It was VERY STUPID, but I wasn't wearing a face shield (last time I'll EVER do that!). Anyway, a piece of wood gave way, and zoomed out into my face, just above my lip. Good thing it was a small piece, or it would have knocked out some teeth. Ended up with a nice cut (to the bone). Luckily, I was able to clean it and get the bleeding stopped long enough to CA glue it shut (yes, that's a good use for CA glue). Now I have a cool looking scar that remind me every day not to be an IDIOT!
Yikes! A 1 tpb rotary saw blade.....!!!
Wow Bill - what a story! I'm glad you healed well and that the damage was restricted to skin and did not involve anything more serious....
In the image you posted, the geometry of the piece of protruding wood at the rim was highly reminiscent of a hook tooth on a band saw blade, with a 1 tpb (tip per bowl) cutting edge! I have gotten minor cuts from sharp rim edges on occasion, but I've never seen anything like this (other than on commercial saw blades and drill accessories!).
Thanks for posting this - I think it will make people more aware that even the simplest things we take for granted as turners can have potentially nasty outcomes.
Turn safely!
Rob
Can I re-tell your Story?
I'm glad to hear that you are okay. I was wondering if you'd need stiches.
I'm the safety officer for my club, and if it's okay with you I'll share your story tonight at our clubs monthly meeting. Let me know.
We just created the "safety officer" position in our club, but not for the same reasons as your club. We have not had an incident, and want to keep it that way.
Tom
my moment of carelessness and gloves
Bill,
Sorry to hear about the damage, very glad it wasn't worse!
I have been pretty good safetywise with the wood lathe. Have a Uvex shield on it's way right now and will use it until I can afford an airstream type.
Slow spinning down is ten times worse with a metal lathe. I was finishing a little play pretty at two or three AM to show off to my benchrest buddies and be the envy of all that didn't have one, nobody else did. I was fitting to almost air tight, aluminum on aluminum. Over and over, shut down the lathe, watch it take forever to spin down from almost eight hundred RPM, reverse direction, ten seconds with a file, watch it take forever to spin down from eight hundred RPM, test fit. Repeat a half dozen or more times. I was spending seventy-five percent of my time watching the lathe spin down. Surely if I were careful getting the end of the file past the chuck jaws I could touch the aluminum with the file while the lathe was still spinning towards me reducing the eternity of watching the lathe spin down by half.
I'm here to tell you that this worked just fine. The file was absolutely unharmed when I touched a chuck jaw with a finger tip, just a gentle brush. Unfortunately that finger and the other two that were whipped into the chuck in an instant didn't fair so well. First thing I did was grab the three fingers as tightly as possible in the other hand to slow the bleeding and hang on for a couple minutes. I couldn't feel what the damage was and was wondering how many functional fingers I had left.
When I finally looked it wasn't too bad, a nail ripped pretty much in half down most the way to the quick and then out the side, very large chunk of flesh ripped to match but still dangling, the other two fingers had no feeling but were still there in their entirety. Feeling did come back a little later! Lots of feeling. My first thought was thankfulness though, could have paid a lot more for that moment of foolishness and I lived alone. The one handed drive to the hospital twenty miles away wouldn't have been any picnic. CA would have worked better but I used plenty of tape and finished my project cursing the blood getting on everything.
I came close to starting a thread yesterday concerning safety and refrained since I am very much a newcomer to wood turning. I am watching many many hours of video from both expert and nonexpert wood turners and I have to say as a whole safety practices are horrible! They will be doing something while busy telling you not to, and the practices around natural edged bowls send chills through me. Accidents are often caused by something you have done dozens or hundreds of times before. A few years ago a machinist was wearing a jacket turning on a metal lathe in a commercial machine shop not too far from where I worked in a similar shop. This time for whatever reason his jacket got in the chuck or workpiece. No nice way to put it, it was a closed coffin funeral.
I see gloves being worn in video and mentioned in posts. I also know someone that insists on wearing soft cotton gloves in the belief they will tear when they need them to. There is perhaps no article you can wear more dangerous than gloves when turning. Gloves get hung in things and whatever they are covering gets drug behind. I have had even thin plastic gloves hold like iron when I was trying to take them off after doing projects not around machinery. Even if gloves do tear they may tear after they have guided your fingers or hand into machinery or workpieces and neither have a heart or soul, they will mangle you without a thought.
I won't bother with a story but there was some impressive screaming going on at the vo-tech for long minutes after long hair was caught in a very slow turning drill press. Loose clothing, long hair, jewelry, anything you don't need on when working around rotating equipment needs to be gone or in the case of hair, well contained. My ex was unhappy that I wouldn't wear a wedding ring. I worked around rotating equipment a good bit of the time and sometimes climbed iron for a living. Rings make wonderful strippers when they get hung in something.
I promised myself if I ever have another metal lathe it will have a brake on it. If I start turning with a wood lathe that takes long enough to spin down to be an annoyance it too will have a brake even if one designed and built by myself.
Sorry for the long post. I have ran dozens of crews over the years and safety is important to me. The first major injury on one of my jobs, over a fifteen year period, was the superintendent. Me. Unloading a truck when it wasn't my job to do anyway. Nobody else handy, just a few things, only take a minute . . . Twenty-five years ago and I still pay every day for that mistake.
Hu
Hand stopping the lathe is one habit that I broke when I moved from a small lathe (VicMark VL 100) to a full sized lathe (OneWay 2436). It only took me a few tries at slowing that thing down to realize there is a LOT more rotational momentum in the larger lathe (even when it is empty).
The OneWay has two stopping speeds (slow and fast). The switch changes the braking program for the motor. I really like that the lathe actually breaks internally.
I will say that I nearly always use the slow breaking. Another lesson – use those set screws on the chuck adapter when turning larger pieces if you want to use the short breaking times…. Otherwise when you hit to stop button your turning will walk around the shop after the chuck unthreads itself from the headstock…. (:eek: insert you own visual photo representation here).
Bill – First: Glad you are OK.
Second: Thanks for being brave enough to share this with us.
Third: I hope this is the last time you get hurt.
Cheers, Tom
I have wondered about some of the more fragile pieces too
Cheers, Tom
Tom,
I didn't realize just the motor programming would be enough to unscrew a chuck. It's a frightening but I have to admit funny visual thinking about what could be bouncing around a shop!
What I have been thinking about when wanting a brake on a wood lathe is the questionable structural integrity of some of the pieces. Seems likely this could be an issue too. Spin down time isn't an issue with my little lathe, I am hoping to graduate to bigger toys though.
Hu
.... I assume you've already received your safety officer award, so there's no point in making a special trip to Fort Worth to cheer your presentation.
This happened a couple days after the meeting. I might write a piece for the club newsletter since we have not had a safety article in a while.
.... I'm thinking you need to build a foot powered brake .....
Great idea as long as the chuck is being braked and not the spindle -- otherwise the chuck might unscrew and start another mess.
Thanks for posting this it will be presented to my club members at our next meeting if that is ok with you.....
You are most welcome to use this at your next club meeting. I posted this to help promote doing things safely and it would not make sense for me to tell folks to keep it under their hat.
..... I especially appreciate hearing that club members share stories of their accidents with each other....
I also think that it is a good idea that our club does this. I hope that most clubs take the time to include safety as part of their regular meeting activities. Perhaps you could make a suggestion in your column that clubs could do something along those lines.
Bill, be honest now! Were you wearing your faceshield?....
Yes, I was wearing my 3M Airstream helmet and had the best view in the house from my front row seat.
.... In the image you posted, the geometry of the piece of protruding wood at the rim was highly reminiscent of a hook tooth on a band saw blade, with a 1 tpb (tip per bowl) cutting edge! ....
The similarity dis not escape my notice especially when photographing the rim. I even considered including a close-up of one of my large bandsaw blades to compare gullet geometry.
.... I'm the safety officer for my club, and if it's okay with you I'll share your story tonight at our clubs monthly meeting. Let me know....
You are most welcome to share this with your club. This was not exactly how I had envisioned achieving my fifteen minutes of fame, but you take what you can get sometimes.
... I came close to starting a thread yesterday concerning safety and refrained since I am very much a newcomer to wood turning....
Please don't let being a beginner stop you from posting on any aspect of turning, especially not the topic of safety. Because of the varied backgrounds of woodturners, each of us is able to bring something to the table that benefits all of us that not necessarily dependent upon woodturning expertise or creativity.
I mentioned my bucket and bowl gouge incident. It was preserved for posterity in our club's newsletter a few years back in this article.
Drum Roll, Please . . .
OK Bill, the committee has been polled and you have been awarded, by acclimation I should add, the 2013 Spring "Charlie" Award. The Charlie is given four times a year to deserving recipients who, while competing for the more prestigious Darwin Award (always posthumous) don't quite meet the Darwin criteria, meaning they survived the attempt.
Your Charlie will be delivered by Airborne Express as soon as the warehouse where the trophies are kept will release it (something or other about unpaid storage fees).
Congratulations! Heal fast so that you may continue your efforts and remember, "Practice Makes Perfect" "Keep You Nose To The Grinder, Your Shoulder To The Wheel, and All Safety Equipment In Your Locker"
:D:D
Bill, glad you ar OK. Nice you added a bit of humor to your story. And glad you chose to share it.
I have tried to develop things that work for me. It is rare I touch the outside of a natural edge work while spinning as I also had a booboo years ago. Not as bad as yours but it did make my eyes pretty big and it took a bit to heal. When I rough out I do wear a glove on my left hand. Those hard flying chips hurt sometimes even through the glove. They would rip skin without the glove. But I am not touching the bowl with a gloved hand.
I try to be careful. I do a lot of very thin turning where my hand is rubbing the outside of the bowl to dampen vibration. Knock on wood I have never had a piece blow up and catch my hand. It would not be pretty.
To the videos saying dont do this while the turner is doing this. I do those things cause I am comfortable doing so. In a demo I do tell folks to not do that unless they are comfortable doing so. I tell them my stories of what could happen. Mostly its adjusting the tool rest while the lathe is on. I would have to think if I do other things in a demo that should not be done in a perfect safety demo.
Kelly,
We had a bit of a discussion on demonstrations and the demonstrator's liability on WoodCentral a week or so ago. Keeping in mind that my comments were limited to the law of the State of New Jersey, you might want to take a look . . .
http://www.woodcentral.com/woodwork...eryone-is-personally-accountable-for-themsel/
John,
We (maint tech group) would often use a strobe to stop or nearly stop rotating spinning objects to help in vibration analysis. Trouble with it was that folk not aware would want to reach out and touch the spinning piece because it looked to be stationary. We never had an accident from it, but did have many hands stopped before getting in harms way.
The worm hole looks like a tooth on a cirlce sawmill blade. OUCH! Hope it heals well.
can a chuck unscrew itself if the brake stop the chuck but not the spindle ?
will the brake work equal well if the lathe are turning clockwise or counterclockwise ?
I use a smooth metal rod or tool held against a smooth part of the chuck to slow it down, KEEP THE END OF THE TOOL AWAY FROM THE CHUCK, I got a 6 inch 4-jawed chuck for my 7x12 metal lathe and the spin -down takes too-long , ONE MORE THING TO REMEMBER, DO WHAT I SAY NOT WHAT I DO
moving too quick can get you hurt.
Thanks for the testimonial, Bill......
Since I converted to variable speed with a Minarik controller equipped with a motor brake, stopping a turning is pretty quick. Seems to me I recall a couple of minor cuts from trying to slow down the turning, but this would have to be prior to changing over to VS. My lathe has a hand wheel, and that would be the smart thing to grab onto........I don't claim to always have done the smart thing, and sometimes it takes doing the wrong thing to understand that it's best to look for another way that is safer. :D
I have an old VHS video by Del Stubbs. Haven't see that video in years, but I do recall him rigging up a foot pedal that releases the belt tension between spindle and motor. He was able to stop rotation pretty quick with that arrangement.
Regardless, the motor brake I now have, keeps me from ever touching the turning to stop it.........
I can't really say what made me put my hand on the turning while it was still turning. It must have been a lapse in thinking because it is something that I do not normally do and certainly not if the piece has "negative space" (artsy-fartsy talk for holes, gaps and other stuff that can hurt you if not careful). Anyway, it was not the smart thing to do. I'll file this away on the same list that includes not picking up hot horse shoes or striking matches to see if the gas tank is empty.
I also have the Del Stubbs video. I think that his lathe was a Woodfast that he rigged with a foot pedal to loosen drive belt tension.
I do have a nice dent in one of my headstock lamps......this has been there for a decade, or so........but, IIRC, I was using a scraper in the interior of a bowl and had a catch. The handle came up and hit me under the chin and put the dent in the lamp. I was wearing a face shield. I was lucky because there wasn't any major injury......maybe some bruising......but, it could have been bad.
I no longer use scrapers in the interior of bowls, except in a very limited capacity. For my purposes in interior work, scrapers aren't a tool to remove wood, but more of a finish tool and a few applications where access is very difficult.
Among the many things I've learned through turning is patience. I tend to be impulsive and have found it doesn't go well with power tools at all. Not to say I won't someday do exactly as you did. Glad you're ok.
Dave F.
Lou Williams is AAW's chapters and membership committee chair and he will be leading a local-chapter-leaders' meeting at the symposium in Tampa. Lou would be the person to communicate this message to local chapter leaders lou@woodturner.org. Send him an email with this suggestion.
Lou also helps write the content of the email messages that regularly get sent to AAW members. That would be another place to suggest that clubs share stories about accidents.
I will continue to include articles on safety in the journal (and will consider how I could include your suggestion). The June issue contains a safety quiz that will also be available on AAW's website for downloading. It was written by a local-chapter member in North Carolina. It'll be in the products/AW area.
OK Bill, the committee has been polled and you have been awarded, by acclimation I should add, the 2013 Spring "Charlie" Award.......
There is a special subcategory of the "Charlie" for woodturners known as the "Chuck". :D
They are functional trophies and I have noticed that some recipients use them to attach wood to the spindle of their lathe.
I have also learned that I am being considered for a "Corrigan" because of my innovative approach to doing things the "wrong way".
Oh, no, not me. I haven't done any stupid turner tricks. Well, not recently. Okay, well, not today. Okay, I haven't been out to the shop yet today.
Really, the most important safety tool is that thing that sits between our shoulders, and is supposed to regulate common sense.
When sphincter tightening exceeds chuck tightening, you have a problem. From 'Pat's Fan' over at Wood Net forums. Love that one.
pretty much the way it goes in my state too
Kelly,
Mark,
I read the thread you linked to. I don't have your legal qualifications but I have noticed things go much the same way in my state. What you told people, what you had them sign, may not carry the weight of what you showed them or what was common practice at a site. What you say doesn't usually carry the weight of what you do. Essentially what you are conveying is one way is the "official" way to do things but it is just fine to do it like you are demonstrating. Some risk but not enough to be worried about. If it was really dangerous surely the expert would not be doing it.
The employer or trainer might win a court case but their odds aren't good in this type of situation. Better to make a substantial settlement than risk going to court if you are given that option and can afford it. A demonstration looks a lot like a seminar to me. When someone giving a demonstration does something outside of safety rules they have the built in issue that they just did it in front of dozens of witnesses too.
I know someone that travels the country training people on high end medical equipment. There are workarounds and procedures that are probably as safe as the documented ones if performed properly. The only reply he can give when somebody asks about these things is that it isn't an approved way to use the equipment. No "but yeah . . ." Not a proper function of the equipment, end of conversation. He would make himself and his company liable with any other reply.
Hu
Isn't it a shame and a ridiculous expense that we have to try and head off the lawyers? Can't remember where I read it, but it was either widely quoted or true that the average annual cost per lawyer in this country is greater than the average salary of a doctor. Or, along with the tech section on Morning Edition this morning, commenting on the shortage of native coding folks, the idea that the trouble with US education is we graduate seven lawyers to every engineer.
In previous employment I had too much to do with lawyers. Reports were written with all measures taken in strict compliance with the (then) current standard of care, regardless what else might have been tried and found effective. Defense after the fact. Not that it would stop legal action. Especially in a state where any level of responsibility can be held liable for full compensatory and punitive damage.
"I do things this way, you may do them as you please." Should suffice. "I won't come to your shop and critique, do me the same favor."
responsibility
Isn't it a shame and a ridiculous expense that we have to try and head off the lawyers? . . .
Michael,
Unfortunately as you well know, anything that starts with "common" isn't common anymore. Common decency, common courtesy, common sense, none common any longer. It is never someone's own fault they came to grief. It is the fault of the deepest pocket that contorted logic can find fault with, if no deep pocket can be found it was the fault of everyone else but the injured party.
Sometimes some truth to that, sometimes not. When safety regulations first came to industrial occupations to a significant degree we sometimes had safety rules that would have reduced production over fifty percent, maybe over seventy-five percent. So we were given safety presentations, forced to sign paperwork, and fired for nonproduction if we actually did what we were forced to sign. In a very highly regulated area of industry someone was written up for "malicious compliance" with the rules. A firing offense to not comply, an offense that impacted salary and bonuses and could lead to firing if you did comply.
We could lay the blame at the lawyers door but we would be stopping short of the real issue. What percentage of people making our laws are lawyers? If we had a healthy mix of all occupations represented in the congress and senate we might have more reasonable laws. All these lawsuits? Class action suits often the lawyers get millions, the offended parties get a coupon. More standard suits the lawyer may be getting over forty percent of the gross plus all legal expenses. That is before medical bills or other real costs of the injured party are taken out. The medical companies and the insurance companies play their own games so ultimately only the individual and the consumer loses. I have seen people get huge settlements, set for life right? Nope, still way over their head in debt for medical bills and genuinely unable to work.
Things are seldom how they appear to be to someone looking at them from only one perspective. No question that our entire system is deeply warped and getting worse all the time though. Fifty-five or sixty percent of people think they are taxed fairly. Fifty-five or sixty percent of people pay no taxes. The lawyers and people employed by the insurance companies and in political office produce little of tangible value. The medical field invents medicine and equipment then finds a need for it. X-rays are becoming a thing of the past because there are higher dollar procedures to do the same thing.
We certainly need some of each but we have long ago became a nation where the tail is wagging the dog instead of the other way around. I really think there should be a percentage cap on how many people can work for the government and how many people can hold political office. Not too many years ago, in the 80's, the USDA was asked how many individual offices they had. It took them over a year to admit they didn't know and had no way to tell!
Oh yeah, we were talking about a minor injury on a lathe in this thread weren't we? Oops! :D:D:D
Hu
Let's get back on topic here. I have no plans to sue myself -- I made an out of court settlement between my brain and hand where I promised myself to watch where I stick my hand when working in the shop. If you want to belly ache about lawyers start your own thread and don't hijack this one.
Don't believe in information evolution? You seem to have left the thread before Mark's post and URL. If you don't care to wade through, read http://www.woodcentral.com/woodwork...ead/id/467473/sbj/where-are-you-mark-mandell/ Sad when things other than turning intrude, but worth discussion, especially for local chapter liability.
Apologies
I am sorry Bill. The original discussion seemed to have ran it's course and a bad habit from another forum where threads usually take fourteen different turns, I did knowingly make a basically off topic post although the thread had drifted into the demo's and such. I didn't mean for the post to be nearly as far ranging when I started but having been on both sides of lawsuits multiple times I have more than the quick note worth of comment I originally intended to post. Not very good at short posts anyway, my nature I am afraid. Can't promise short posts but I will try to do better at keeping them on topic!
Back on topic, are you going to do a reenactment for video?
Hu
Actually, I read your post as primarily a discussion about safety. I hate to act like I am the Internet police (reminds me of a Country music song BTW), but at the same time it is hard to pass up a opportunity to twist MM's tail. :D
I suppose that I could do a video since people generally learn better visually. I guess that I need to find an actor to play me in the video. Maybe Norm is available -- "Before we use any power tools, let's take a moment to talk about shop safety. Be sure to read, understand, and follow all the safety rules that come with your power tools ....... And remember this: there is no more important safety rule than to wear these — safety glasses." I don't know about the plaid shirt and tool belt though.
Bill,
I posted the link in response to Kelly's contribution, not to get anyone started on a jurisprudential discussion, but rather to focus on the issues of personal responsibility and teaching "safety and safely." You, of course, have taken personal responsibility for your mistake and posted here as a valuable effort to teach a "Don't Do What I Did" moment.
There are two ways to approach shop safety, regardless of what tool (powered, otherwise, or how we're dressed ;)) is being used: Defensive or Offensive. We can approach the issues with a negative attitude like "I better do not this because someone's gonna get a lawyer and sue me when they get hurt after seeing me do it," or in a positive mind-set of "Since it's likely that someone will get hurt if they try this, what can I do to make this activity safer so it's less likely to result in harm in the first place." The AAW has taken a dual approach through its insurance program and its affirmative outreach efforts to teach safer methods and to strongly discourage unsafe practices.
Oh, by the way, let's not forget that the most important piece of safety equipment we have is located directly behind our eyes and between our ears. Leave that 'in the locker' and you give up all hope. Kevlar a foot thick won't protect you from "stupid."
Bill I thank you for starting the thread and its good intent but beleave you were right in saying it had gone off topic, it was not a club or work accident was it so the need to stray was not needed ,just my 2 cents worth.
ian
Threads are pretty much like being in a group of people having casual conversation. It's not reasonable to think the directions the subject matter take can be strictly regulated. The conversation will go where it will go......and, when it veers off, it can get more interesting.
For those who think the subject should remain on topic, it could be changed back to the original theme by adding content that tends to re-focus attention.
There is no right or wrong in this. The point has been stressed over and over, and I can see the frustration of those who want a thread to stay on topic.....but, I can also see the point of those who have interest in the twists and turns of a more casual conversation.
My 2 cents, as well.
