Well, I have this insatiable need to experiment..... Generally you want to sharpen nothing but 'hardened' steels on your CBN wheels. So just about all of our turning tools, shovel blades, axes, bench chisels, and probably a few others will do fine. I had an old set that didn't cut well any more after many years, and I also tried to touch up some carbide on them. It did take the carbide down, but that really dulled the wheels. So, just to see what would happen, I ground some aluminum, brass, copper, and cold rolled steel on the wheel, which left very visible colored rings around the wheel. They were gone in about a month. You can feel softer metal building up on the wheel. There is a noticeable ticking sound when it starts to load up. Best way to get it off is to take a scraper to the wheel to sharpen it. It may take a couple of times to get it off, but the scraper kind of peels off the built up metal. I also regularly put some lapping fluid on the bevel of my tools before sharpening (this is in my platform sharpening video). This also helps loosen up metal build up and the sludge that comes from sharpening tools with wet wood on them. Dave Schweitzer of D Way (now owned by Jimmy Allen of Boxmaster Tools) said that it doesn't hurt to take your wheels if they are looking black from all of the accumulated gunk, soak them in water with detergent for a few hours and then use a bristle brush to clean them off. It gets the deep down in stuff off of the wheel. I always sharpen my Big Ugly tools on my grinder. They are tantung (almost as hard as carbide but easy to sharpen on standard grinder wheels) which is silver soldered onto bar stock, which is one of the soft metals you should not grind on the CBN wheels. Little to no problem with build up since the tantung peels off any metal that builds up. I do grind off most of the bevel on the bar stock on a belt sander, and keep it pretty much that way.
So, you may be able to ruin a CBN wheel by really loading it up with soft metal, but it would be really noticeable. If you get a little loading, you can clean it up simply by sharpening a scraper a couple of times. I would not make a habit of sharpening softer metals on the wheels though.
Oh, I did retire that one set that I ground the carbide on. I did grind off the points on some galvanized screws, which left black streaks on the wheel, but didn't seem to bother the cutting action...
