Have spalted maple log that have cut into two blanks. Have turned outside of one and appears fungus still active. Other has some work to do to stabilize some over spalted areas. This is a gift that I need to get to friend soon so cannot let rough bowl or blank sit for year plus.
Am internally debating the following on the partially turned blank
A. Bring into house and place in coolest part of house...... which happens to be pantry. Let it sit till the spalting stops. Not sure how long this will take
B. Take to local kiln as is. If I do this would likely take second blank at same time.
C. Rough turn inside then take to kiln
D. Finish turn inside then take to kiln.
I do expect to get distortion as drying occurs. Depending on amt. might leave in or try to turn out later.
Any and all thoughts appreciated. Pict of partially turned bowl below
Don
Don
