Hi all,
Long time reader, first time poster... I have been turning for a few years now and I have come across an issue with my latest project that is causing me serious issues, so I was hoping for some ideas!
Basically I am making a pepper mill but I have decided to do 3 small stone inlay bands near the top of the mill that has the recipient's family birthstones in it. The first 2 bands I have managed to do using crushed aquamarine and crushed black opal and they turned out reasonably well using the standard method of filling with crushed stone and thin CA then cutting away the excess with a carbide cutter then filling with smaller stone/powder and more CA then sanding. They look great (well the aquamarine looks rather blah, but that is the nature of the stone I think).
The problem is with the last band which is for the April birthstone, diamond. Obviously I am not going to do a diamond inlay given the cost... so I decided to buy some diamond powder and some cut cubic zirconia. I laid a small coating of the diamond dust at the bottom of the channel and then put the cut CZ on top of it (a combination of 1mm and 1.5mm stones). It created a really nice, sparkle. However, when I tried to cut back the CZ it completely destroyed the look of it since the stones just turned white at the top. So I decided that I wanted to try to re-do it and this time fill the stones slightly below the wood line so that I could just lay CA on top. That way it would keep the sparkle and be protected. However I am having an impossible time with it. I have never been good with CA finishing, so I have avoided it...
I tried thick CA, but it turned white in spots and looked terrible.... same with Medium CA. I have thought about leaving the stone a bit proud so you can feel the texture of the cut stones but I am not sure how to protect it.
One of the issues seems to be the fact that the inlay is just under 2" round so when I fill it with the CA it drips and pools at the bottom. I don't have a variable speed lathe, or I think I could turn it at something like 25 or 30 RPM to even it out... but that doesn't work at 600RPM. ;-)
So basically I am looking for suggestions as to how to put a clear coat on top of the stone that will sit in place while it dries and that I can sand to a clear finish... I am open to any and all ideas...
Thanks!
Thanks!
