Congratulations to John Lucas for "Lost and Found" being selected as Turning of the Week for January 13, 2025
(click here for details)
Exactly what John said. And my experiences have been that without adhesive backing is better, just glue it on using thin layer of epoxy glue. Will be more durable than adhesive backed and when you have to change the hook material you can simply turn it away in a lathe and glue a new piece on...
When I was at the Richmond symposium, I purchased a piece of 6"X12" cloth backed Velcro hook material from The Sanding Glove for $6.95 + tax. I'm certain that they also had the self adhesive backed material, as well as other sizes. If it is not on their website, then I would give them a call.
Personally, I think the self adhesive is too low of a melting point for power sanding. Go with the no adhesive and use solvent based contact cement as it is more flexible.
I ended up ordering some from Industrial Abrasives. I bought some of the 1/2 sheet size used to convert clamp type sanders to hook and loop. They are a great source for hook and loop sand paper in the 3 foot sheets as well.
The heat build-up from power and passive sanding doesn't seem to have the same detrimental effect on the glues used in these pads than anything I've tried, including the self-adhesive versions.
