Thanks Leo. It’s a big scraper so I have a lot of grinding to do to make it a negative rake.Kevin I have one of those thick scrapers, it is HSS, the grinding of HSS give sparks that are a reddish spark color.
This is what carbon steel sparks look like, shown in this picture, to me the sparks kind of explode coming off the grinding wheel and are a much whiter color, normal carborundum grinding wheel or right angle grinder.
Easiest way I know of, grind it a little bit on regular grinding wheel and see how the sparks coming off look - there's readily visible difference between HSS and Carbon Steel, I've found.
