Sometimes I want to mount a very tall hollow form and do a bit more sanding or cleanup inside the neck area a bit deeper than I did when I first turned it. Based on the shape I may also want to be able to sand and buff the finish deeper inside. Nothing heavy and slow RPM or even turning by hand, no real risk for catches or snags. The piece will have been second turned and fully sanded. It may also have a final or near final finish on it. My standard steady rest wheels will leave a compression mark or mar the finish. When the piece is very tall I don't want it just suspended by the tenon hanging out 30" from the chuck.
Question - anyone know of some soft wheels that would work? Not squishy soft foam but maybe wider than normal and easily conforms to the shape without much pressure. I searched the forum and didn't find anything. If I missed it pls point me there.
