I turn green wood to finish thickness, and let them dry and warp. I use the cheap brown soap. The only thing I have noticed that the soap does for these bowls is make them much easier to sand out. I use Mahoney's Walnut oil for finish, and it doesn't bother that at all. I have used other oils (Deft) for some pieces, and it doesn't bother that either. I don't think it would bother water based finished, but haven't tried it. The soap does leach some colors out of the woods. I keep a tub for the black walnut separate from the others.
