Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Will Armstrong for "Gold Carved Bowl" being selected as Turning of the Week for May 20th, 2024
look up my article in American Woodturner. You can also go to YouTube and type in John lucas router demo. It will bring up a demo I did for Gwinett woodworkers guild.
Here's some flutes with a varying radius down the part. Most older furniture uses this style of flute done on complicated Rube Goldberg type machines. They traced a pattern as the part rotated. For one-offs they may have been hand carved since setting up the automated fluting machines was too time consuming.
The variable radius flute to my knowledge can't be done on any of the common fluting designs I've seen. It can be done with an ornamental turning lathe, not so simple there either though. I did some fluting like this when I was into ornamental turning. When you realize how simplistic it is on a CNC the OT route becomes way too tedious.
CNC, with a slight spiral, again needing little if any sanding.
