So, I have space which is essentially a 1-car garage (without the car About 10-ft wide by 20-ft long (there are a few odd shapes where the stair goes up to storage space, that I cannot use for shop storage). I'm attaching (I hope) a quadrille-grid.
This will be my shop space.
Where should I put the lathe? Should it be near the center of the room, so I can access all the way around it? Or should it be near a wall? I'm leaning center-of-the-room, using battleship E2/E3/E4. I have 220V outlets at E2 and at A6, but I'm thinking of putting in the dust collector at A6. The heater will be along the A3/A4 area (garage is insulated, but not centrally heated. Winters can drop to -30 F at night outside). Lighting will not be an issue (there's plenty of artificial lighting). I'm a bit constrained in that C1 thru C6 is the passageway from real garage (where the cars are) to house entry; my spouse will not want to dodge equipment while carrying groceries.
The grinder will be behind me, wherever I choose to put the lathe. Other equipment will include a bench, a bandsaw, and shelving.
Thanks!
Hy
Thanks!
Hy
