I found this and think it is very good. Answers a lot of questions. Hope it is okay with the moderators.
http://www.youtube.com/watch?v=ZOc6giDP39A
Informative
The only point I was disagree with is his comments on CBN vrs friable wheels,
Doug stated that his K course wheel cost him $50/each and last 500 tools, while the CBN costs near two hundred.
I know a CBN lasts more then say 2000 tools, probably closer to 10,000 tools
That means while the CBN costs more "up front", it's life-time cost is lower
informative video on all aspects of shaping and sharpening tools.
Just a pity safety was not pushed a bit more , loose shirt and microphone wires getting close to catching and resting on the top of a bench grinder with a spinning wheel is not a good look.
Does not matter how many chisels or tools you have done but in an environment where you are supposed to be showing how things are done properly it was not a good look.
Hu,
A mouth full of shavings is much worse if you are chewing gum at the same time. Been there, done that, more than once.
