sharpening angles on tools and other tips on cut quality
What I've learned so far. I have been playing with angles for quite a few years now trying to learn the what's and why's. It gets very complicated. Not the angles, that's easy. The more acute angles cut cleaner but don't hold an edge as long. More acute angles can be a little grabbier (if that's a word) if you aren't a skilled turner. For example when I was teaching more I learned that students had more catches with a spindle gouge ground at 35 degrees than one ground at 45. I don't notice much difference myself now but then I've been turning for about 35 years.
In actual use I will make a cut. If it doesn't cut the wood clean enough I will switch to a gouge with a more acute angle on the edge. Typically on bowls I start with my normal gouge which is 55 degrees ( or around there, I don't worry about exact angles, I'm looking for usable angles). If that's not cutting clean enough I'll switch to a 40 degree gouge. If that doesn't work my spindle gouge is 35 degrees. If that doesn't work I'll switch to the Hunter tool which has an angle about 27 degrees.
OK that sounds simple enough, BUT, if the bowl is deep you can't use the 35 degree gouge because the handle will hit the rim when you try to keep the bevel rubbing. That's where the Hunter tools come in, but I can talk about those in another article.
What I'm finding is there are lots of other factors besides cutting angle of the edge that affect the quality of the finished cut. If you force the cut, meaning pushing the gouge faster than it wants to cut, you get a less finished surface. Lathe speed. Slower speeds tend to make you force the cut easier. Higher speeds which can be dangerous of course, seem to help keep you from forcing the cut.
Tool angle. That is the way the wood crosses the cutting edge. When the wood crosses the cutting edge at 90 degrees you get a fast cut but a somewhat course cut. When the wood crosses the edge at an angle ( or skewed cut) you get a cleaner cut. The steeper than angle the cleaner the cut, but the tool cuts slower. So when your having tearout problems try looking at the cutting edge and see if you can rotate the tool to move the cut around the cutting edge so the wood passes at an angle. For example when rolling beads with a spindle gouge I usually start with the flute up and the wood at the top of the bead passes the edge at 90 degrees(we will call that 12 oclock) As I roll the tool over to cut the sides of the bead the wood is passing the edge at a slight angle so the sides of my beads would usually be cleaner than the top. I started rolling the gouge slightly for the beginning of the cut so the edge that starts to cut is about 11 oclock which is at a slight angle to the wood passing the edge. This leaves a cleaner cut. Hope that makes sense. I do grind my spindle gouges using the wolverine jig so the left and right edges roll around more than a lot of tool edges coming from the factory.
Edge polish. If you sharpen your tool to a finer grit you have a more polished bevel. This seems to affect the quality of the cut. I've been playing with different grits for sharpening and can tell the difference in the finished cut if i use a higher grit to hone or polish the edge. Of course if you really slow down the forward feed of the cut you get a burnished edge from this polished bevel. There seems to be a fine line between a clean cut and a burnished cut. If you sand afterwords it won't matter but if your cutting clean enough to not sand the finish may react differently to the burnished wood vs the cleanly cut wood.
Grain direction. It should go without saying but if you cut downhill with the grain you will get a cleaner cut than uphill against the grain. This is kind of what got me started playing with all the parameters above. When finish turning the outside of bowls so that I can finish the foot, I found that the last 1/4" or so has to be turned against the grain. You know that little section just before the foot where your gouge won't fit in either a push cut or pull cut. What I've learned now is I can usually go to my detail gouge that is sharpened at a 35 degree angle and clean up the last little bit so it requires little sanding. In fact if you combine all of the above, not forcing the cut, use a more acute edge, polish the edge, and cut with an angled or skewed edge, you may not have to do any more than touch it with 400 grit to finish the bowl. \
You'll notice I haven't talked about scrapers. I don't use them often simply because I can't get as good a finish. I'm not as skilled with them as Richard Raffen. I will use them when I haven't succeeded in getting as clean of a shape as I want with my gouges, however I don't claim to be an expert with a scraper. I'll leave that discussion to others.
Oh I'm sure there's more but my brain is still reeling from the last 9 days on the road. Thought I would give my take on this topic while waiting for the shop to warm up and then I'll sit back and read all the arguments pro and con later. Have a good day,
John,
Nice overview.
Like you, if I don't get a clean cut with my normal process, I till try tools with more acute grinds a spindle gouge often cleans up and a high shear angle with a pull cut will also often do the trick.
Related to angles the Length of bevel also has a big effect especially of interior cuts. I know you grind micro bevels.
Short bevels have less bevel drag, negotiate interior curves better. These reduce vibration and allow the tool to be over the tool rest a bit further with minimal vibration.
A short bevel often eliminates the need for a bottom feeder cough as the short bevel turn up 45 degrees or higher changes the handle position.
The micro bevel taken to extreme is the Michelson grind and excellent grind for thin work and hollowing - almost no bevel drag.
The November Fundamentals has a reprint of an article by Philemon Brenion using the micro bevel to hollow with a pull cut.
A cute angle? Couldn't resist. More pointy works for me, and I agree, they tend to catch more easily. It sounds like most of this was directed towards spindle turning. For sure, the higher the shear angle, the cleaner the cut is because it is much more gentle in getting under the fibers and lifting them up. Less resistance.
For scrapers, the only time I use a scraper for a finish cut, in scraper mode which is the cutting edge at 90 degrees to the wood rotation or flat on the tool rest, is when doing box lids and bottoms. I use a negative rake scraper. Any other time I am at a shear angle. It is easier to control, and less resistance to the cutting action.
For the polished edge, the only one I hone is my skew, and I almost never use it. I can get a better surface on my rolling pins with a shear scrape. Maybe I need to turn as many rolling pins as I do bowls..... I haven't been able to tell that it makes any difference on my bowl gouges. I don't have a 60 grit wheel to try on my bowl gouges to see if the 'more serrated' edge cuts better as some like Mike Mahoney claim.
When playing around with the burrs on my scrapers, I go back and forth between the 80 and 180 grit CBN wheels. I think I prefer the burr from the 80 grit wheel for just about any cut I make with my scrapers. It seems to be a little more heavy duty, and hogs off for roughing cuts better, and does shear scrapes better.
Tons of info here. Setting up a belt/disk sander to sharpen what few tools I have. If I figure correctly, you started turning when you were 4 years old? ;)
Another thing to consider is bevel angle along with pressure on bevel and direction of cut. I have found particularly with newer turners is they don't quite grasp or maybe better way of saying it is they don't quite have a feel for the cut as more experienced turners do. As you gain experience you learn to guide the bevel not push on the bevel it to hard. Many turners use the Ellsworth or Irish type grind. These grinds have a 60 or so degree bevel angle on the nose thus some push on the bevel hard which really is pushing out on the bowl rim area as well.. The tool handle has to reach clear across the lathe to start a cut and start down the side which becomes more natural to push out on the bowl. Many of these same turners have had very bad catches with the Ellsworth finish cut therefore are gouge shy to try it again, thus they stay more on the nose bevel rather than roll to the wing bevel. I tell them if they are having trouble with tool marks to go back to the basics which is 45 degree nose bevel. You are pushing more towards the headstock (rather than out on the bowl) because the handle is more in line with the lathe bed or even a 35 degree gives you more push angle to the headstock. Although a bit more grabby you do get a cleaner cut because of the pressure and direction of the push cut towards the headstock. That 45 degree is really a useful teaching tool and back to basics angle. Bevel angle, wing angle, standing at the lathe angle, flute to rest angle, shear cut angle, entry cut to bowl angle, tool rest to piece angle and etc. and etc. are good 45 degree learning angles for people (starting angles) and for those who have lost confidence and trying to get it back.
I hope that makes sense.
Good thought. The only problem with the 45 degree bevel is many beginners make bowls that have steep sides and then they can't make the transition cut going from the side to the bottom. In that case the 60 degree bevel may be better However they also have a tendency to not ride the bevel in which case the 60 degree bevel becomes a scraper and may be a little more foregiving. Of course if your teaching and can get them to make a shallow bowl as their first then the 45 degree angle would be great. I'll have to try that next time I do a bowl turning class.
Dale your comments on technique make a lot of sense to me.
When I first started teaching in my second or third bowl class, I had a student who couldn't get his gouge to cut on the outside of a bowl. The tool was bouncing behaved as though it were terribly dull. Student said he had just sharpened it, so I tried his tool and it made a nice cut for me. He tried his tool and same non-results but this time, watching carefully, I notice he was pushing the bevel against to wood so hard the the cutting edge could not engage on the convex bowl. I pulled back on the end of the handle and the tool cut great for the student. I did't know you could do that at the time.
Now I always stressed not holding the tool too tightly
I used to hold it way too tightly and when I did I was always keeping the tool from doing the work.
I took a class with Liam O'neill in 1995. He assured me I did not need to grits the steel so hard he made me turn the outsides of bowls one handed.
The next year I took a class with David Ellsworth. I still needed some fine tuning so he had me turn the insides of bowls one handed.
I wondered about that, myself.....!
The thing to remember about lathe turning, is what works this time may, or may not be what works next time. There are many variables, and even one piece of wood of the same species as another, may require different tact to get the best cut. Don't get frustrated.....try something else. There is always a best way to handle any situation, and if you make rules for success, you are bound to be frustrated plenty!
ko
I was a big fan of the swept back grind gouges for a few years. I would swear that my first Ellsworth gouge had a 45 or so degree bevel, but can't remember. Anyway, I almost never use them any more, and perhaps that is a skill I should relearn. I prefer the 45 degree bevel/sweep. I tried the Batty 40/40 gouge, and just found it too pointy for me. On the outside of a bowl, or convex surface, bevel angle makes no real difference, depending on what you are used to using. The 60 degree bevel will go down the sides, and for most bowls through the transition and across the bottom. I still prefer the 45 degree bevel for the walls, and switching to a bottom feeder type tool for the transition and bottom. For me, they just work better. Of course, I still prefer my scrapers for the heavy roughing... Learning to feel the cut is a skill that that takes time and practice.
From an old movie, "Hold the sword (turning tool) as you would a bird. Too tight and you kill it. Too loose and it flies away."
From some one else, unknown, "The bevel should rub the wood, but the wood should not know it."
Learning the one handed cuts is a huge help.
Yes....true that.
Another factor that is just as important, is to hear and know what the many sounds made by the cut mean. A slight adjustment in presentation while the cut is in progress will mean all the difference in the world, and you can learn to make the adjustment without stopping the lathe to check.......
ko
