I just discovered this turner through Mike Waldt, who also has some excellent turning videos up. Love the steady rest too:
https://www.youtube.com/watch?v=_BRDGq551PA
And I waste all that time cutting my sand paper into small pieces, lol.
 Yep, he just uses the cheapest paper and uses it like an old shop rag.  I spend all kinds of money on fancy pants sandpaper, cut it in quarters and fold each quarter into thirds, spend ten fold as much time sanding, and maybe almost get results half as good.  I'm not even going to talk about my relationship with the skew.
I also see that if you are really good with the skew then you can cut uphill.
A lot of that depends on the wood itself. With some I often cut uphill; with others the tearout is a problem. Some woods even chip when using a skew on a thin cylinder or even a downhill taper - I have a supply of Osage Orange that does that, but fortunately it is quite clean with a gouge.
I could not help but notice how short his skew is. To me that means the handle has to move more distance to achieve result. Is it possible that that makes the works easier?
I watched a Craft Supplies video on sharpening the skew to round the end (could not remember the grind) . I tried on a old cheap skew and it is much better. Never could figure how to sharpen it that way.
Oh, I tried his web site and it comes up not found.
What I call a short bevel is the tool ground lets say 60 degree included angle. Long bevel would be more like 30 degree included angle. With the short bevel using my definition you swing the handle further to turn square sided beads than you would using a 30 degree bevel...
....... Curved edge skews are better for planing cuts and parting style cuts. I don't like them for turning beads if the curve is too great because it's hard to see what your doing. Maybe I'm just used to using a straight edge skew for those cuts but that's my story and I'm sticking to it.
I don't cut my beads that way. I roll the skew over the bead so the tool starts at about 90 degrees and then is pushed out to finish the bead. So both tools start about the same but the short bevel skew has to be pushed further to finish the cut. Look at 8 minutes into the video to see how i turn a bead......
Duh ....... I just had major senior moment here! I got so fixated on how to depict how the cutting edge and wood meet in a 2-D drawing that I completely forgot that you can do the same thing much more easily in the real three dimensional world by simply rolling and tilting the tool at the beginning part of the cut and avoid most of the swinging the handle side to side.
Bill.....Even if you do tend to "overthink" once in awhile, I'm sure I'm not the only one who appreciates all the obvious extra effort you tend to put into your posts. It serves to make the rest of us think a little more broadly than we would have otherwise!
ko
Well it makes us think. that's a good thing. One thing I get out of teaching is trying to understand how to explain things. They are very easily misinterpreted in print which is why we all get so confused on these discussions.
 For larger hollow forms, I have a broom handle with a big ball of sandpaper on the end, but it was too large for this piece.
  For larger hollow forms, I have a broom handle with a big ball of sandpaper on the end, but it was too large for this piece."If at first you don't succeed ... so much for skydiving."With that in mind, we really shouldn't be so shy about learning the skew, don'tcha think?
 Having said that, I've had my share of runback and catches with the skew, but the spindles tend to stay between centers. Comparable mistakes on a bowl with a bowl gouge have more serious implications, but the feedback is sometimes ambiguous. I MAY have some idea of what I did to send the bowl flying out of the chuck, but I think I always know what I did wrong with the skew.
there's a stopper I want to turn that is square in part of its profile (as in the picture below), so the pummel cut comes into play.
Oh, you are too kind. Nope, it's from Woodturner's Catalog (projects -- wine stoppers)Oh, I like that design. Is it yours?
Shhhh, don't tell me that. This is supposed to demand a skew, so that I will practice, practice, practice.A spindle detail gouge with a fairly pointed nose would also work for that pommel cut. I would probably try both (on my practice cuts!)
I turn my stoppers (From SS Niles) using her mandrel. Regardless, yes -- I think the blank has to be perfectly square, and hole/mandrel perfectly centered to get that pummel thing just right.I've turned a number of spindles with square sections, mostly "magic" wands (the magic is how many people want one!). The trick is getting the square blank centered correctly in the first place. Easier for me to turn between centers - I make small holes with a gimlet for the points to fit in. Harder to center by grabbing the square in a chuck since the jaws cut into the wood, my usual method for bottle stoppers:
I had more success maintaining alignment by turning a cylinder on the end of the blank between centers then fitting that into the chuck.
I have resorted to using a sanding block after the turning to adjust the flats. Is that cheating?
This is the first turning project I've ever seen fit to name. I'm calling it "I like bowl turning"
robo,
Identical on purpose but purely by luck.
Thats why the pic is a little out of focus and not a straight on shot...also counting on a coat of paint and maybe the few inches between when installed...
I'm grasping at straws...hoping when its all said and done it'll look ok...
All in all, it was a good exercise, but I think I learned my lesson...I like bowls...
cc
robo,
cc
