My Cremation Urn is presently on the lathe. The wood being used is Cherry which was salvaged form a table I built that floated around my house after Hurricane Katrina.
I have requested that a jigger of Macallan 18 year old single malt be poured over my ashes prior to sealing the urn. The ashes will later be scattered at the grave site and the urn will be reused for another member of our family.
No doubt the addition of scotch whiskey to the urn will create some wood movement. I am trying to allow for this in the design. I cut a rabbet in the bottom ring and intend to insert a slightly undersized plug in this opening. My question is what type of glue to use for this purpose. I want the glue to be just a bit flexible, but it needs to hold up over time. I was intending to use Epoxy to glue in the threaded brass insert for the lid. Will this be a problem if the upper part of the urn moves?
