segmented ring press
Canton, GA
Do any of you folks have a reference to anyone selling a segmented ring press? I am having trouble finding the necessary parts to build my own--I would like to buy a good already made unit if I can find one.
Thanks for any feedback/info--Don
Mine is two pipe clamps, pipe, pipe flange, formic base, and 4x 4. Works quick and can apply lots of pressure if needed.
A ring press is really not necessary. I have made dozens of small (6") segmented bowls without using any sort of press. Build up the ring stack one ring at a time. Apply glue to two rings (or base and first ring), rub them together to uniformly spread the glue, align the segments and set aside to dry (30 minutes or so if using Titebond). Repeat until the ring stack meets requirements. For larger bowls I use the lathe as a ring press. Cone in the tailstock to center the smaller rings. Cole jaws to hold and center the larger rings. In both cases it's better to build the ring stack one ring at a time. Don't apply glue to all rings at once and attempt to align them and apply pressure at the same time. Way too many moving parts for this to work reliably. - John
Paul's suggestion is my favorite. :D
If you don't have a wine press laying around, then John King's suggestion seems like a very good way to go. Disclaimer: I have never done any segmented turning, but I have made wine many years ago. :)
Don, appreciate the lead, I've looked at the Stomper before, and I can't figure out how to do closed segment rings on it--do you know how???
At 13:50 in the video he shows that by adding a Longworth chuck at the bottom, closed segments can be centered easily.
Thanks to Don for starting this thread. It pointed me to sites and links which have helped me understand what might be required to start turning segmented bowls and what might just be nice to have and maybe acquired after I have some bowls done. It turned out to be a great resource starting point.
Randy, I have to admit I have tool-obtain-a-mania, so I'm often looking for a tool that one could make for their self, but I really like well made purpose built tools--I plan on posting what I ended up with soon also--still open to input from folks!
Based on my recent better understanding, you may not have to buy anything at all initially. The Wedgie Sled looks like it's not that difficult to make out of something stable like MDF. The wedges are the important part because the angle you set the fences at must be accurate and they can be bought online. However, to start, for 6, 8, 12 segment rings, standard 30, 45, and 60 triangles should work. The assembly part is certainly facilitated by the Stomper, but it appears you can make the plunger part of it. The only thing that might facilitate things are the plates on the bottom that also sold online. Here again, I would assume that you can assemble the rings with hose clamps for smaller rings and band clamps for larger rings at least to start. I, too, love to accumulate tools, but, in this case, would likely only acquire some assembly plates to start with in a few sizes I would like to start with. Anyway, the whole thread really gave me a series of resources which really helped me put the basics in perspective.
