Satin Sheen
ARCATA,CA
Greetings, I have a number of green turned tanoak bowls that I've finished with a sealer coat of 2 lb. shellac padded on topped with 3 light coats of Liberon oil finish also padded on. I would appreciate any suggestions as to how I could get a nice satin sheen finish on these non-food bowls. Thanks in advance, Michael
Liberon Finishing Oil is meant to be applied to bare wood, allowed to soak in for about ten minutes, and then the surface wiped dry with a clean cotton cloth. You should allow at least five hours between applications if you want additional gloss. One application will give you a matte finish while a second application will give a satin sheen and a t,hired application will produce a soft gloss. Oil finishes should never be applied over a film finish such as shellac, varnish, or lacquer as they will prevent the oil from penetrating into the wood.
These Tanoak bowls were turned green, then dried prior to finishing. My satin sheen solution:.. Light Beale tripoli buff of the Liberon oil finish....Then if customer wants a lower sheen...liberon 0000 steel wool or 3m synthetic steel wool rub.
Michael
Are you using the sealer solution after drying? Are you re-turning to round or sanding or anything after green turning and drying?
Steve,
On totally dry bowls; 1 thin coat 2 lb. cut blonde shellac padded on as a sealer...next day light rub w/ gray synthetic steel wool. The reason I turn my bowls green (aside from not being in love with dust) is that I want the controlled asymmetry of the shape & especially the tactile grain undulations which are non-existent in dry turning & dry sanding...So no re-turning to round, or any significant sanding except w/ synthetic steel wool.
Just my preference. Michael
