I got this link from another forum. The sandpaper tests may be of interest to some here. Spoiler alert, Cubitron Xtract comes out on top.
View: https://m.youtube.com/watch?v=NZDCRFi8dKY
It isn't really paper per se.. It is a pretty strong mesh (Can't tear it no matter how much I've abused it) and the 5" disks work fine (and stick better than properly sized paper disks) with my DeWalt ROS, after I switch out paper I can set the used ROS paper aside and get some more use out of it at the lathe (the very flexible mesh , I almost want to say Kevlar, lets it conform to beads and coves pretty nicely) It's my Go-To sandpaper anymore, it outlasts my (I used to use Serious Grit paper) older regular sandpaper by 2 to 1 or 3 to 1 easily. I read about "might need an interface pad" when I first got my sample pack long ago, but so far, this Xtract is the ONLY sandpaper I have ever used that does NOT come flying off the sander (or drill mandrel) after so much use.. I consider 3M Cubitron to be THE premium sandpaper for any woodworking project and well worth the initial higher cost per piece.I'm not very knowledgeable about mesh sandpaper, which I think the 3M Xtract is. I've stayed away from it because, on RO sanders, I need to buy interface pads and I didn't think that you could use mesh when you are sanding on the lathe by hand with just paper.
Does anyone have a source which explains more about mesh paper and what is required. It seems like the cost per gram of mesh goes up when you factor in replacement of the interface pads (or maybe they aren't use up fast enough to make a significant difference).
The purpose of the interface pad is not to keep the "paper" in place. It's to prevent wear and damage to the RO sander's pad. Without the interface pad, the RO sander pad will wear and need to be replaced. With the interface pad, the wear will be on that and that, of course, is much cheaper to replace than the sander's pad.It isn't really paper per se.. It is a pretty strong mesh (Can't tear it no matter how much I've abused it) and the 5" disks work fine (and stick better than properly sized paper disks) with my DeWalt ROS, after I switch out paper I can set the used ROS paper aside and get some more use out of it at the lathe (the very flexible mesh , I almost want to say Kevlar, lets it conform to beads and coves pretty nicely) It's my Go-To sandpaper anymore, it outlasts my (I used to use Serious Grit paper) older regular sandpaper by 2 to 1 or 3 to 1 easily. I read about "might need an interface pad" when I first got my sample pack long ago, but so far, this Xtract is the ONLY sandpaper I have ever used that does NOT come flying off the sander (or drill mandrel) after so much use.. I consider 3M Cubitron to be THE premium sandpaper for any woodworking project and well worth the initial higher cost per piece.
Ah. I see.. Well, oddly enough, I don't seem to have an issue with wear on my sander pad (I have a spare laying around, as it started to get gummed up with fibers from poor quality sanding disks, then I got the bright idea to use my file card brush to clean up the Hook & Loop facing, have not had any problems since, and it's been a year... and I figure if I get a year's almost daily use out of a sanding pad, which is actually a "consumable" part, I'm doing pretty good)The purpose of the interface pad is not to keep the "paper" in place. It's to prevent wear and damage to the RO sander's pad. Without the interface pad, the RO sander pad will wear and need to be replaced. With the interface pad, the wear will be on that and that, of course, is much cheaper to replace than the sander's pad.
Suppose perhaps it is the holder? I got mine I think from woodturner's wonders (6 of the roloc type holders to go with a roloc drill mandrel - 2 inch ) and have been using mostly 80 grit 3" cubitron, but have had no problems on rather limited use of the cubitron xtract paper.... but then I also don't have my wave edge disks (also from woodturners wonders) flying off those pads either (unless I catch a disk in a crack, chip or on natural edge.. and even then not every time)I briefly tried one size of the Cubitron mesh discs and had a hard time keeping them on my velcro disc holder. Has anybody else tried power sanding with it and what was your experience?
I admit this has been frustrating, but do you find any makers still using CAMI? I thought FEPA had pretty much taken over.Typically, European manufacturers use FEPA/P Grit and US manufacturers use CAMI, China, that's a bigger issue. But they don't always state which system they use.
You can read my comments on the YouTube video, which I posted 6 months ago, and have not been replied to. You can download a grit chart HERE
Check at Taytools.com - Taylor Tool Works.. Thats where I been getting mine from both 5 inch and 3 inch (dont think they have 2 inch)Where are 2" and 3" Cubitron discs available?
My question is the second one downI admit this has been frustrating, but do you find any makers still using CAMI? I thought FEPA had pretty much taken over.
(There are 860 comments on the video, so I was not able to find yours)
Have a contractor order it for you. Probably get a better price alsoI am looking into getting the cubitron in belts for my drum sander. 3M only wants to sell to contractors, not the general public. I don't think they have a clue as to how big the hobby market is. The cubitron discs are available in 2 and 3 inch, but I have gotten used to the ones from Vince which are 2 3/8 and 3 3/8, and prefer that over size disc. The hooks from the interface mandrill can leave 80 grit scratches.
I tried to scratch the wood with the hook and loop and haven't had any luck. That must be some real durable H&LI am looking into getting the cubitron in belts for my drum sander. 3M only wants to sell to contractors, not the general public. I don't think they have a clue as to how big the hobby market is. The cubitron discs are available in 2 and 3 inch, but I have gotten used to the ones from Vince which are 2 3/8 and 3 3/8, and prefer that over size disc. The hooks from the interface mandrill can leave 80 grit scratches.
