sanding sealer before acrylic paint?
Michigan
I have a piece that I am working on and I am going to have someone else decorate it with acrylic paint. The piece is Bradford pear, do I need to use a sanding sealer before she paints it and if yes, what would be a good choice?
Because it is a closed grain wood there aren't large pores to worry about sucking in the acrylic finish. However, if it is something like a vase that is turned end grain then it wouldn't hurt to use a sealer to insure that the finish will be uniform in appearance. If using an artist acrylic paint like Liquitex, sealing probably isn't necessary. Make sure to use a sealer that is compatible with the topcoat. Sometimes the term acrylic can mean different things (such as acrylic lacquer or acrylic enamel or acrylic latex).
Sounds like I might better just seal it to be safe. I have never used a sealer before, are there any differences in them and what would you recommend?
Manufacturers often recommend a specific sealer (made by them, of course) when using one of their topcoat products on bare wood. If you are unsure of selecting a sealer, it wouldn't hurt to follow their recommendation. You can also do an Internet search to select a sealer.
Wouldn't shellac be fine for almost everything?
I just happened to run across this on the Rustoleum Zinsser website: Technical Data Sheet for Seal Coat
It says that Seal Coat is 100% dewaxed shellac and is suitable for all topcoats. I found this while watching a Jimmy Clewes demo where he says that he cuts it 50-50 with DNA to achieve deeper penetration into wood fibers and it dries very fast.
Yes, thanks Bill. I should have specified DEWAXED shellac. Thin with DNA, but might want another coat. The Zinnser spray can is fairly thin and easy. Just make sure it's fresh.
I didn't know that Zinsser Seal Coat came in a rattle can. Jimmy Clewes says that he thins the sealer which is already thin because he doesn't want to see any of the sealer on the surface. His goal is to have all of it soak into the fibers so that the topcoat won't be sucked into the fibers. Of course, he was using dye on the wood so his aim was different than what you are doing.
Bill,
I use the spray Zinsser a lot as a sealer. Lowes has it and if I recall, Walmart too. De waxed
No matter what you do run a test first when mixing any medium. Doesn't take long and solves the question of "will this go over this".
Bill,
OK, but is it Zinsser® Bulls Eye® Sealcoat Universal Sanding Sealer? The Rustoleum website only shows it in quart, gallon, and five gallon cans. Regular shellac is fine as a sealer especially if the wood is open grained like ash and red oak where other sealers are too thin to seal large pores.
Their regular shellac is available in rattle cans. They have a synthetic shellac primer/sealer called B-I-N 1-2-3 Primer but it has some white pigment in it. It is mainly for covering knots in wood and water stains in drywall -- two things that will bleed through paint.
Bill,
The picture that Douglas posted is the product I'm using.
