Like Dave said, a bunch of very small and usually very short cracks, and on the end grain. I have seen the same thing from torching the wood to get the color, and especially if the wood is still kind of wet. It is not easy to do on dry wood, you have to spin pretty fast and apply a lot of pressure. I am not sure it can be done with any of the power sanders, you have to do it with hand sanding, and more often the finer grits. If you are hand sanding and have your hand on the wood, you can feel the heat, unless you are using a sanding pad. Never do the sanding pad thing, it lets you know when the wood is getting too hot...
