Sanding Discs
Haubstadt, Indiana
I have primary used 2” disc, but going to get a set of 3”. I have been happy with Vines’s Blue Flex and 2Sand White Rhyno. I’ve been looking at Vince’s Platinum and Klingspor Latex backed disc. Any experience with these or other disc to consider?
It has been a while since I experimented with anything other than Vince's blue discs. I haven't found anything else to be a comparable value. The blue cut longer and faster than any other disc I have tried, so I get more for my money.
La Grange, IL
I write the number on the back of the disk, but that's an annoying problem with abrasive paper in any form. I just bought some rolls and the first package was cut from a section of stock with no grit markings at all (I wrote the grit number on the inside of the cardboard spool).
Cleveland, Tennessee
I have the penturner's set of sandpaper rolls. I tear off a piece to finish pen blanks and write the grit with a Sharpie.
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
I also recommend the blue discs from Vince.
Let's face it.....there is no magic in sanding discs. The ONLY purpose is to remove wood at a particular grit grade......nothing more, nothing less! :D
I started out using the Merit power-lock discs back in the early 1980's, and I'm still using them as my primary sanding discs today.....because they work, and they work very well. I have tried a few other brands of discs, but I just can't see any real advantage......you can pay more, and not get as good performance.....or, you can just pay more! A long time ago, I can remember hearing the Merit discs are too aggressive......but, it's like having a big engine in your car......use it when you need to, but you don't have to "pedal to the metal" all the time!.....learn to back off a little!
Many of my bowls have undercut rims, and the flex-edge discs have been a very useful boon to sanding in these areas.......For this, I have a cut down mandrel that only holds the flex disc in the center. That disc is capable of flexing almost completely around on itself.....it's incredible, really! :eek:
One of the biggest drawbacks to sanding is learning when to toss the paper, or disc you are using.....and replace it with fresh paper/disc. This was a tough one for me, but when I finally got it through my thick skull to toss it out (even though, technically, it would still cut), my sanding procedures were immediately, and immensely improved with better surfaces, ready to apply a finish.....and with much, much, much less overall sanding time! Having said that, it is imperative to understand that sanding will never replace good tool work.......it's just like applying the finish.....it's all about "surface preparation" prior to your starting the procedure at hand......it sure makes things much easier that way! :)
(If you can regularly start your sanding at 240 grit, and sometimes at 320, and occasionally at 400 grit.......then, YOU have arrived! :D)
Shelby, MI
Made a cup shape sanding disc to smooth surface of spheres,,,,,homemade, works fine,,, odie, I probably replace my paper/disc sooner that you do, but hey, whatever works.
I'd be interested in hearing a little more about your "cup shaped discs", Ken.......:D
Photos would be nice......;)
Torrance, CA
I needed some new sanding accessories. Woodturners Wonders had this set and a picture of a set up like this. I always felt I wasted too much paper, even marked with a Sharpie. This made sense, paper stays on the Reloc foam disc holder, holder is interchangeable on the mandrel. It looks good; I will see how the longevity factor is.
Brandon, MS
I have the set . Been using kinda heavy for me for over a year and holding up well. They will get the job done with soft and firm pads makes it a great option for sanding. I have a hex setup so I got the extra set of mandrels for deeper sanding , eventually you will need them. The only complaint I could have is that the shortest one is not quite as short as I wanted so I cut one off and made a bead on it.
Torrance, CA
I found the soft pads worked well without the mandrel, just hand holding them. Way easier to grip than just paper alone!
