I enjoy turning on the lathe. I do not enjoy sanding. Is it better to run the lathe at high speed for sanding or low speed. Which do you fellas prefer. Thanks.
Thanks guysI run the lathe fairly slow 300 rpm
I use 3” and most 3” Velcro pads on an angle drill at high speed.
Not sure what the rpm of the drill is but it can’t be all that much
I watch for a stream of sanding dust coming off the bowl.
If it is not there time to switch sanding discs. Or slow the lathe down
Thank you much!Abrasives cut better at lower speeds, generally speaking. I know there are some who use an angle grinder with sanding discs, where the grinder turns about 10,000 rpm, but I would think one has to be very light in their touch or burning would occur.
Thank you SteveThe challenge/problem with turning at high speed, is that you will over heat the sandpaper and the wood. With the wood over heating, there is a tendency for the heat to cause cracks in the wood surface. You want to thus turn at a slow speed and try and keep from over heating the sandpaper.
The higher the speed, the more heat you generate while sanding. When I started out turning, I created more than a few surface cracks in pieces by having the speed too high, and the sandpaper too old.I enjoy turning on the lathe. I do not enjoy sanding. Is it better to run the lathe at high speed for sanding or low speed. Which do you fellas prefer. Thanks.
Another rule is if you are melting the velcro on the sanding pads, you are going too fast! I would not recommend an angle grinder for sanding.Easy rule--- If the sandpaper is too hot to hold while sanding, it's too fast.
(almost sounds like a Foxworthyism)
