Rough Morning
Whole morning off with no obligations, so I hit the pile, even in the drizzle. By the time the first two were done, this great golden object had appeared in the sky. I can barely remember the last time I saw it.
Twice more, and time to empty the shavings. Can't give them away just now, so I ended up dumping down the road, with help, as noted.
Then I saw another sign of spring. Gesundheit, everyone!
Looks like the sled dogs get the summer off!
Yellow clouds drifting over the lake from the pollen as I type. Black flies are protecting the front door.
MM
You need to make friends with a potter that does wood firing, they pack all the pots in saw dust/chips. My local potter takes all I can produce.
Dr Dewey
I'm just guessing here, but I'll bet it's a water thing. They look like they will be stacked to produce a fountain. Although why a wood fountain might be a question.
n7bsn said:
MM
I give mine to a person with a couple of horses they will be glad to take them as well.
Neighbors
Michael, I just know we are neighbors, even tho you won't admit it. That yellow ball (forgot what it was called) appeared at 11 am here in south mid Michigan for the first time in ????10? days. I quit turning, and mowed the dandelion skeletons, as it has been 10 days. MY sweat shirts have not been put away. :) Gretch
Yes, I leave the pillars in. I run the Forstner down the slightly constricted hole and remount on the pin chuck after drying the pieces. Easy and safe way to round the outside and retune the recess. Has an additional unintended benefit in that it keeps things open on the shelves, so they don't mildew as easily. Does take more room, but ease and safety are important to me, and I have tried a lot of other ways that didn't work as well.
The chicken lady is full up with shavings right now. I like her, because they come back after the chickens are done with some high-value innoculants! Musty stuff isn't really favored by the horsey types, and this old maple produces a heavy wine-smell, and molds within a day in the bag. Plus, the stuff just under them is cherry, which the horses tend to chew. Later in summer when I rough, I bag the shavings in cotton sheets and dry them rapidly for bedding and tinder. Don't ever make the mistake of giving away planer shavings with their uniform size and ease of handling. People will turn up their nose at coarse lathe stuff thereafter.
Only one RAKU type in the area, and he's got sawmills for supply.
I was able to mow the home area myself, Gretch, though I'm in T-shirt and short pants by now. Ended up doing the grocery shopping at 8 pm because dry grass waits for no one, while the market's open 24 hours.
mowing garb
MichaelMouse said:
. I was able to mow the home area myself, Gretch, though I'm in T-shirt and short pants by now. Ended up doing the grocery shopping at 8 pm because dry grass waits for no one, while the market's open 24 hours.
I was dressed in less than that!!! :D Gretch
Weather
WOW
That almost sounds like the change in weather we had here in wetter Washington. Last Friday I awoke to the sound of the heat coming on (it was 65 in the house). Last night I heard the A/C turn on (it was 80)
Earliest I have had the A/C turn on, since I had A/C
Raku is only on of several wood fire "firing" methods
The things you learn when you are friends with people that make things out of mud...
I know a bit about other soft-fire types. My favorite mud slingers are high-fire stoneware producers. I like potters, especially on juries, because we share a lot in common with them that the two-dimensional paint daubers will never understand.
If you invite one over to your house, of course, he'll leave with a crick in the neck from trying to visualize what's going on 90 degrees out of orientation. I do more swapping with glass and pottery types than any other when out selling. They're my kind of folks - earthy.
