• December Turning Challenge: Tree! (click here for details)
  • Congratulations to José Esteban Cruz"Rocking Horse" being selected as Turning of the Week for December 16, 2024 (click here for details)
rikon 70-150VSR needing a surge protector
Albany Oregon
hi all
i have a rikon 70-150VSR on a dedacated 15 amp circuit only thing on circuit is lathe and light and have had to replaced 2 controlers first 1 cane up error code #4 called customer service and they sent out a new controler than about 6 mo later it started comming up error code #3 they sent me anouther controler and told me i need to put it on a surge protector can anyone point me in the right direction as to best option? i realy have no idea what is needed do they mean like the surge protector strip i plug my computer in to? or something else?
thanks for any help ...Neb
Clinton, TN
Maybe call customer service again and ask what surge protector they recommend..
Clinton, TN
Geez... the size of that link, apologies.
When I copy a link from Amazon, I copy only the text before the “/ref=”. Anything after is unneeded, perhaps related to the search algorithms that led to that page. For example, for your long link I would only copy and paste this (without the quotes):
https://www.amazon.com/BSEED-Appliance-Protector-Voltage-Brownout/dp/B07R3GK6DM”
This is especially handy for sending someone a link by email.
The forum software, in this case shortens the whole thing to a the simple and vague link name “Amazon.com”, at least for me:
If this is too brief, you can always provide some descriptive text from the page, something such as, in this case, “BSEED surge protector”
Albany Oregon
hi john that link came back "sorry cant find it" thanks anyway
Clinton, TN
I didn't read all the posts to see if you figured it out, but the example line was pasted inside of quotation marks so it did not make a valid link. It was intended as an example of how to extract a link from a long bunch of characters copied from an Amazon search that contained the link.
That line, copied from the address on the Amazon page as described will take you directly to the page. (as illustrated a later in the message). It won't work otherwise. (The line won't even work if you just copy the text from the message and leave off the quotations marks) This is sometimes confusing, but after doing it a few (dozen) times it becomes automatic. I've used this method for years. (Although I always test it after posting and fix it if I accidentally messed up a character. I hate links that don't work!)
BTW, you can copy and paste the text of the entire line into the address field of a browser, delete the enclosing quotation marks, then press enter. That works.
Spencer, NY
I have the same lathe and had a similar problem. I purchased an Amazon Basics surge protector and haven’t had a problem since. Unfortunately the one I bought is no longer available but I’ve attached a photo. Something similar should work fine.IMG_0096.jpeg
