Hi all,
So, I turned the bowl in the attached picture last weekend. It's a shallow bowl with an undercut rim. I ran into a bit of an issue when I turned the bowl around to finish the bottom. Because of the curvature of the outside, cole jaws would have nothing to grip on, and a jam chuck would easily crack the thin rim.
What's the best way to reverse chuck something like this? I eventually ended up making a "loose" jam chuck just to roughly center the bowl and holding it in place with the tailstock, but I was still having trouble. Eventually, I took it off the lathe and hand-sanded what was left of the bottom.
This was just a practice piece, so I looked at this as just a learning experience. I'm just wondering what is normally done on a shape like this to hold things in place.
Thanks! And happy Friday...
Dan
Dan
