• Congratulations to James Seyfried, People's Choice in the September 2025 Turning Challenge (click here for details)
  • Congratulations to Bill Clark for "Meadow Lark Symphony" being selected as Turning of the Week for October 6, 2025 (click here for details)
Prevent build up in flute?
Campobello, SC
Been turning quite a bit of wet Bradford Pear (for the first time) lately and getting hard buildup and caking inside the flutes. Also on the nose but that easily comes off when sharpening. It affects the cut and is not easy to get off. It doesn't just wipe off, I've got to scrape it. It builds up quickly and really slows things down. Apparently the gouges are getting hot but even slowing way down doesn't help. Any suggestions on how to prevent and /or quick way to clean out the flutes while working on a project? Is this something particular with Bradford Pear? I've never had this happen before and have turned quite a bit of wet species. No issues with dry stuff. Thanks for input!
Some times lubing the flute helps like with Pam or WD 40. Madrone is really sticky like that. Mostly I just wipe it off with shavings before starting again.
If the gouge is getting hot you may be pressing the bevel too hard.
Friction causes heat. I try to float the bevel so there is minimal bevel drag. Many wet woods create a bevel grab with the sap build up. I sharpen my still sharp gouge when I sense bevel drag. I want to float the bevel.
I keep a gouge slip stone on the grinder.
I use every time i sharpen when turning green wood to polish the flute.
If I’m not turning green wood I use the slip stone when I feel the flute edge has lost its polish.
1/2 of a good sharp edge is the surface I’m grinding into.
I'm interested in this too, as I am also processing some big green BP logs. I have to try waxing my flutes before the next one. Of course I get the same buildup and sticky crud. Maybe it's something to do with the sap, as the tree I'm working on was just felled a week ago. Interestingly, when I was finish scraping the exterior clean on my last one, I kept getting a wet, sticky brownish gray-green mud build up on my tools.
Sometimes I will stop and scrub the flutes and bevel down with 0000 steel wool soaked in mineral spirits, which works when I'm not too much in the zone to bother with it.
Something about how you present the gouge is going on. I didn't know you could get a hot tool in wet wood. I get long curls with nothing small like you show way down the flute. Try rotating the gouge , or dropping the handle to get more of a shearing cut. I think you are getting close to using it like a scraper.
Aaron, the build up you describe is what I've been getting and haven't seen this before, just on this BP. I've also used mineral spirits and/or lacquer thinner, but it's a hassle to stop and mess with it when you're humming along. I'm not far from you, just outside of Campobello. Moved here about a year ago so working with wood that's new to me. (Just noticed my profile has my old location, guess I better update that!)
Thanks everyone for the speedy and helpful tips. I went out and turned another bowl this afternoon after reading your comments. Hockenberry, thanks for the reminder on floating the bevel. I thought I had been, but made a conscious effort to lighten up and that did help out some. When the crud did build up and harden, a slip stone worked best to quickly remove it. Toothbrush was only good if used right away when still wet, and a variety of brass and other brushes didn't work that great once hard. WD40 didn't help but surprisingly, paste wax made a difference. So new routine for me while turning BP - apply some paste wax to flute, wipe off crud with toothbrush (or rag) when wet, use slip stone when hard then reapply paste wax, use light cuts. These steps don't add too much time and is way quicker than having to stop and remove that hard crud by other means.
Anyone else run into this issue or is it just me?
Also, I think I'm getting decent shavings . . .
Well, howdy, neighbor! And for the record, it's pronounced "Campbeller" unless "you ain't from around here" lol. I call BP "The Forbidden Tree" since it was outlawed. When you have the reddish-orange heartwood without too much of the treacherous pith, it can be stunning, and finishes with even more luster than maple or dogwood. It is truly one of my favorite domestic hardwoods, and I brought home a good ton of it last week in my truck-bed that I hope to turn all of before it cracks to firewood (though it cracks a lot less for me than cherry or worst, dogwood, which I have about given up on as too much trouble). Your shavings look great. I have been taking out trash-bags full of them this weekend, as I turned a very large live-edge one Sunday.
I also plan to try some of the methods listed here for the crud removal (though scrubbing with mineral spirits on steel wool does the job very well-though I need to add that step with the paste wax). One other thing I have been doing with my live edge turns recently is to coat them immediately with shellac inside and out (but not the bark) before putting them in a grocery bag to slow down the drying process and hopefully prevent most cracks. So far it's working well, and not too difficult to sand off for other finishes once dry.
Maybe I'll see you around Upstate turning events. I am in the Carolina Mountain Woodturners club, though it's a bit of a drive, so I only go to a few things every year.
Thanks for bringing this to my attention. The pics might not be too great, but the stuff that is on the flutes is hardened "crud droplets", not shavings. That's the best I can describe it. See my other pics for the shavings I'm getting. But you are right, the gouge is getting hot which I've not had happen like this with other wet wood. I mainly use a push cut with a 40/40 or Ellsworth type grind, but when I use a shearing cut, I still get build up. Scrapers definitely build up but are easy to clean off.
Ha! Good to get the pronounciation corrected. Having moved from Hawaii, I know how it can be a challenge.
Getting used to the climate and seeing how radically it changes wood here has been interesting. I've embraced the warp. This forbidden wood came from a large branch of a neighbor's tree. I suspect there will be more available after this new storm blowing through. I've mostly been turning this to finish thickness and then microwaving to dry and warp with decent (I think) result. I have rough turned a few pieces and will try your shellac method.
I'll check out that woodturners club. I was going to join the Greenville Woodworkers Guild but that's too far to make it a regular thing. Guess I'm getting lazy.
Afterthought, I have one small high speed grinder that has a wire wheel on it. Perfect for flute cleaning, BEFORE sharpening.... Some times I take my scrapers to it as well, and great for deburring just about any tool.
I have a piece of hardwood dowel about 12" long that I have shaped one end to match the flute shape. I us it in a scraping/ pushing motion to scrape gunk from the flute before sharpening.
On wire wheels, I had my old 6" starter grinder just sitting around doing nothing, so I put wire wheels on it, coarse and fine. When these wear out will replace with nylon, but huge help to have them easily available.
I read an article a while ago about the benefits of polishing the flute. If it’s not as smooth as it could be it can have an effect on the sharpness. But negligible I suspect if you’re only using a 180g wheel. The other issue highlighted though was indeed build up in the flute. The advice, if your gouge could look better, was to polish the flute and then wax it I believe.
Keeping a high polish inside the flute tip also makes the task of cleaning out the crud easier and it also contributes to a finer and more stable edge when grinding the bevel side of the edge. I do that to the flutes of my gouges with an 8" rag wheel loaded with chromium oxide mounted on a bench grinder... tip pointing down and trailing, of course!
I do the same with all of my gouges. When sharpening, I clean the crud out with a dowel, then clean the flute with a one of Alan Lacer's diamond slipstones. Every so often I take them back to the wheel and re-polish them.
