portable air compressor
Madison, Indiana
I have been using a porter cable pancake compressor and have been having trouble fixing an air leak in the head. Replaced about everything you can replace and have not been happy with it at all.
Can someone give me a good suggestion for a better one? I need one that is portable for I use it out of the shop also. Thanks Gary
The air leak would have to be in either a plumbing joint, drain valve, rust hole in the tank, the pressure gauge, the quick disconnect, or the air intake valve -- there is nothing else. You can either dunk it in a large container of water or mix a small amount of detergent in water and brush it on all possible leak areas -- just like you would do to find a leak in a tire. The quick disconnect is the most likely culprit and the pressure gauge is second on the list. The most time consuming and expensive to fix is the air intake valve which is probably a thin metal flapper. If the leak is really fast, it is very likely that the flapper is either cracked or has broken off completely, in which case it may have been swallowed into the cylinder. This would require a rebuild kit that consists of a cylinder sleeve, piston, intake and exhaust flapper valves, and gaskets. Many years ago, I paid about $50 for one of these kits, but I am sure that it is much more now.
In the land of 15A clones, my DeWally double tank appears to be about the same as either. Iron head single stage, handle for the strong to move it, same features, probably same castings. While I wouldn't try to save money by buying the clone at HF, I would say go with price on similarly-featured name - not house - brands.
Sure looks familiar, but I'd be looking over my shoulder every time I turned it on. http://www.harborfreight.com/2-hp-4-gallon-115-psi-twin-tank-air-compressor-95498.html
