Do I buy the PM 3520b at 15 percent off or do I need something with a 3HP?
I am a beginner.
I like to turn bowls 12 - 18 inch. I want to use a coring system. I have access to big wood and bigger wood fairly often.
Does the PM have enough power to use a coring system (easily)
Does the moving headstock lead to vibration?
Would you rather have a fixed headstock and have to lean over the bed or a sliding headstock and work off the end?
I don't want to say money is no issue, b/c it is always an issue. Having said that, I could go 10k for a Oneway or VB36- The question is should I. I only turn in the winter. I bass fish in the summer.
Will the 3520b be all I could ever need or should I go to something else. Should I get more experience before I step up to a top-line lathe?
Thanks for the input
I am a beginner.
