Platter Contest Winners!
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
The results are in, our judge, Keith Gotschall, has picked his winner and here are the results with comments
After looking through all the entries, I realized that I had to draw up some guidelines for myself if I was going to judge anything. They were all very good, and that made it pretty tough. My congratulations to all the submitting turners. I looked at the rules and #2 on the list says that the article was a starting point, so that was my benchmark. I was looking for turnings that used the technique that I wrote about, but that then took that idea further. There were other turnings that used other techniques and they are all valid of course.
In a different contest, with a different aim, I might just have a new set of "winners". Be that as it may, there were turners here that did exactly what I wanted to see and I applaud their efforts, my choices
are:
First place- Dick Kelly
Second- Kefferpl
Third- Garmar
Bernie- Interesting use of flawed wood, goes well with the burned treatment. I like the simplicity of the single detail. One suggestion, it might have been better if the bowl had just touched the detail. In the photo it looks like it overlaps and seems to push the detail out.
Kefferpl- Great use of technique showing your own use, bringing your own style to the project. I wonder about the transition from rim to bowl. I actually like the way the leaf tips bend into the bowl, but a softer transition between the two planes of rim and bowl bottom would have been better..... or keep the leaves, tips and all, just on the rim. The piercing was a nice touch that really makes it look completely different and lightens up that heavy overhanging rim.
Bill Pottorf- Nice use of the chuck. Very restrained and crisp. Your turning really appeals to me, the details are nice and crisp and the black plays off well with the cedar. Not using the same technique makes it hard to compare, if I had used a different criteria for judging, this would have done very well. Over all nice form and good execution. How close was this to the other platters you've seen? Just curious.
Barbara Gill- Good use of figured wood with a detailed design, it doesn't always work having a busy wood with busy details. Looks like you cut into the outside bead, I might have taken that last bead out too. In doing so you might have evened up the beads a little, though I realize the outside of your bowl area might not have let you do so. You seem to have the technique down, so what's next?! How can you experiment and change the design to suit your tastes?
Clifton C- Nice! I like it very much. Good to see some new ideas. Simple form, yet some exciting visual details. I can't quite make out what is happening with the base. I like that it looks like a separate piece sitting on the turned base, is it one piece? You have handled the off center turning well. Crispness is something I look for.
Garmar- Terrific job! I really enjoy how you have subtly changed some of the details from the article and come up with a very different feeling piece. I looks like the bowl met up with the outside detail well. Hard to tell about the flat part of the rim, might have been better done, a little crisper, but like I said it is hard to tell from the image I have. I am also curious about the underside and how that relates to the top surface. I think a wider bowl, even if it was heavier would make a strong form.
Sterling Sanders- Wonderful turning. Very strong and pleasing visuals. You used a different technique... maybe there is an article there? As one poster said you have strong visual motion, and the title is entirely appropriate. I loved your use of copper, I am a real sucker for it. I would have liked to see crisper details on the outer crescents, your inner shapes have more definition, a hard arris, and I respond better to that than the more rounded shapes. Can't wait to see the next one!
Dick Kelly- Wow! Wonderful! Dick, you took the idea and put your own spin on it, and that is really exciting. The off-center rim gave you a great place to play with your narrative, and I always enjoy a good pun (visual or verbal) At first glance I wondered about the strong streaks going through your composition but then I got it. The transparent color was a good choice as your carving was simple (Not a criticism!). The colors seem to make it sort of cartoonish to me, and I love that. This is a very strong turning, which is why I chose it as first place.
Here was the posting with the entrants
http://www.aawforum.org/vbforum/showthread.php?t=3744
Keith, I have no idea. I have seen other platters done with other chucks in magazines advertising the Sorby chuck etc. This platter was totally designed and thought out by myself in order to learn the techniques of using the new Escoulen Chuck. It starts out as a football shaped turning i.e., a half dome on top and bottom. This is while mounted on the chuck. Then all of the fun starts. The border around the platter was carved with a v chisel and then textured inside. The blue border was painted with an airbrush, covering the textured area. Reverse turning was the real problem here. Took awhile to figure out how. Thanks for the kind words. :)
Bill Pottorf
I am suprised!!! What a great grouping of turnings, very proud to be selected. I was trying out a new technique as described in the latest AAW Journal on off center platters. There are two things, in my opinion , I need to convey: One, the Journal is getting better with every issue concerning techniques and projects and Two, I liked Barbara's Platter more than mine.
Garmer, I agree about the Journal but not about the platter. I really thought yours was excellent.
Thanks to Keith for taking the time to judge.
To Barbara and all. Thanks for the congratulations. (Is it true that you can tell how new someone is by how tardy they are in joining threads on currnt topics in the forums?) I've only been turning a short while, and decided to try the forum contests as a skill-building exercise a couple of rounds ago. I posted my entry near the deadline, so I saw all the excellent entries as they came in. So, when I got the results, I sent my teachers and woodie friends e-mails titled "Summer Surprise." I, too, kept my Journal open to Keith's article and followed along, step by step, through a couple of practice pieces before I got the hang of the design. I appreciate the clean work in all the entries, but especially liked your pierced and caved approach, Paul. Have you taken any workshops in this technique?
Dick K.
Thank yous
Dick
I like you just read the article a half dozen times, then spent a week deciding how to follow the articles technique but somehow be different. Then carefully follow the steps.
Many thanks to Keith for writing the article and for being our Judge. Also, thanks to the web site workers for all you do to keep this place up and running so we can have a contest. I should have posted this last week, but I’ve always been a little hesitant about posting because of lack of experience. Thanks to all.
Pics of Platteres?
I missed all the fun due to my job. where are the pics of the platters?
The link above goes nowhere.
Thanks
Jorge
Good point, I did change the url to point to the thread on this database.
You can still look at the photos, but they are on the old server, so the time is limited as they will get dumped in about 3 weeks.
