Congratulations to John Lucas for "Lost and Found" being selected as Turning of the Week for January 13, 2025
(click here for details)
Depends on your pens. If they are mostly gentle curves or straight areas it is a good tool. In the hands of a skilled turner you can rub the bevel and it's a really great tool. It depends on which Hunter tool and the skills of the turner.
For pens I would recommend the new mini hercules. It can be used similar to a scraper so it's extremely easy to use and leaves a good finish. It is not a good tool for turning small beads and details when used as a scraper. If you tilt it to the side and use it as a bevel rubbing tool it will not only give you a high quality finish but can be used to cut beads and coves.
I did a very short section on the mini Hercules at the end of my Hercules video. I'm not a big pen turner. I've probably done a few dozen or maybe a little more. I have however turned lots of small turnings and the Mini Hercules will let you do them. It is a really great tool for small boxes. http://www.youtube.com/watch?v=vzrLN8SQ8ms
