Pecan Update (the end is nearer) phew!!!!
Marion texas
Evening folks, I posted a thread in October on here concerning suitability of pecan for turning, just thought I would keep you updated, the the first log is cut up turned into bowl and vase blanks, all fully sealed, last log is sliced into either 16inch or 20 inch widths and will be dealt with in the same manner, except for 4 sections, that will be turned over and covered with thick black poly, hopefully to spalt, some beautiful wood very straight grain and striped in places, some very dark lumber too,, as a novice turner I'm looking forward to turning it, guess I won't need any more pecan this lifetime.
The tree is aprox 180 years old, and girth measurement at 4ft up was 166 inches, texas state record is 143 inches, and the guy gave it, and delivered it to me for nothing, I enclose the original pic and the updated one. the only problem were some boring beetles very very small, but where they had been it left black lines and holes, all these boring beetle marks and holes was in the outer 5 inches of the sapwood, all that has been cut off, but did find laquer thinners injected in the holes with a hypodermic syringe killed the beetle, larvae and sort of melted the eggs, have a great xmas everyone.
regards peter
Marion texas
waltben
Slice those disks into at least halves, or better yet quarters (considering the sizes!). If you haven't already seen 'fire place wood' checking, you'll get it very quickly from unrelieved drying pressures.
the slices are already sealed and will shortly be sectioned into blocks for bowls, vases and quarter sawn for platters , all will be sealed up as the first log was done. As for the sections which will go on the ground for spalting they will go into 1/4 sections, have some high nitrogen liquid fertilizer poured on 2 of them on the side in contact with the ground, then sealed from the top with thick black plastic, the remainder will spalt naturally without an accelerator, thank you for your advice though,
regards peter
Williamsburg, VA
Pecan
Well, that is one enormous haul! I had one a few years ago and will only offer that, if you can turn it now you will end up with some wonderful pieces in the ruff. If you wait you will be turning concrete! My2Cents. Philip
Newport, Oregon
Thank you
Peter, I really enjoy posts like yours. Kind of like ready a good short story. Thanks for taking the time to share.
