Hi - I’m getting ready to start gluing up a segmented bowl. Bottom is about 4.5” diameter, top ring about 10” diameter, seven total rings, 5” height.
I have the bottom paper-joint glued to a 5” face plate, and had intended on adding a ring at a time, truing it up, adding the next, and so on. Is there any reason why I can’t do it this way? I’ve seen in various books where the author built up the bowl that way, but after truing up the last ring, the interior was cleaned up and sanded, then the whole thing was removed and reversed onto a jam chuck for finishing the exterior and bottom.
I don’t have a jam chuck and certainly not one large enough to capture a rim of 10”. I had thought I could use my SuperNova 2 chuck with the 12” Cole jaws attached to accomplish the same thing. Does this seem like a doable procedure, or am I going to have to build a huge jam chuck?
